soap bubble surface
All  1-13  14-18
2754.14 In reply to 2754.11
< that's the reason why I would really recommend Patch
But there is not yet Patch in MOI?
2754.15 In reply to 2754.14
Correct - that's why I recommend using Patch in Rhino for this situation.
2754.16 In reply to 2754.15
Your image here will make the same result than a "Patch" or it's an approximation?
2754.17 In reply to 2754.16
It's an approximation. Patch basically works in that same way, but has a fitting process that adjusts the surface to go through (or at least attempt to go through) some curves that you pick.
2754.18 In reply to 2754.17
Thank you BurrMan and Michael for your network-tips. I had already ruled out the idea to make a larger surface and trim it, because all I could come to think of was to make a surface of revolution and then trim that, but that wouldn't have worked for those eight cornerpoints.
The important thing for the surface is really that it's smooth and that it blends together well once you start copy it. And the networksurface seems like it does both.
Thank you very much both of you, I learned a lot.
/Lars
Show messages: All  1-13  14-18
