MoI - Big Wishlist thread - Post your wishes here
 1-11  12-31  32-51  52-71  72-91  92-111  …  152-157
275.52 In reply to 275.24
I'd also prefer Arc: Start, End, Point on Arc.
I know the interface and tool set of MoI is intended to facilitate the use of a
pen and tablet, but I was wondering if it would be possible to implement
arrow keys to move an object? (the way nudge keys work in Rhino)
There are times when it's faster for me to precisely shape a curve by
nudging control points, rather than jerking them around willy-nilly with the mouse.
Jesse
275.53
A few new wishes.
A reminder...
Michael, the first post of this thread is a list of my wishes... One can be very useful and maybe easy for you to add for the next beta...
11. Add more solids : For example a tube, a pyramid...Why use booleans for these.
Wishes No 7 (images) and 10 (cap ends) are already done !!!!
A new one : (small) When using array command, there is no need to enter a number in X and Y spacing when I choose to make a [1,1,n] array, that means having multiple objects on Z axis.
A new one : ORTHO - Being able to move only on X, Y,Z axis. That can be achieved with Shift button or just a shortcut. I guess everyone will find it useful.To do this now you have to select the MOVE command, and have GRID SNAP enabled. I know that when I drag an object I can see if I move parallel to an axis. What I need is more to be sure that I can't move off axis.
A new one : Some right click menus will be very helpful.. Maybe there are not many commands for this right now but "Hide","Show points", "Copy/Paste" etc can be placed there.
EDITED: 24 Jan 2007 by JTB
275.54 In reply to 275.53
I could be wrong, but doesn't using Straight Snap and Construction Lines accomplish
pretty much the same thing as Ortho constraints? Actually, I find it's more versatile.
In the example, I'm moving the sphere, using the Origin as base marker to
create construction lines in X,Y and Z and at 45 degree angles.
There are many ways to "skin a cat", MoI just happens to have some good all-purpose tools. :-)
Jesse
275.55 In reply to 275.53
Hi JTB - in MoI the "Straight Snap" is intended to be a replacement for Ortho, make sure it is highlighted in the bottom bar when you want to do ortho drawing.
It doesn't just show you when you move parallel to an axis - it is a snapping aid that has some gravity to it that helps you to move parallel to an axis.
Just make sure you see the tracking line when you click and you will have the same result as Ortho.
You can increase the snapping strength if you want, this will make your point "stick" to that line a little easier - to do this, move your mouse to the Straight Snap button at the bottom of the screen and click on the little menu arrow that shows up, and choose "Straight snap options".
In the options dialog, set both "Activate distance" and "Keep active distance" to a larger values, maybe something like 20 and 20.
That will increase the gravity of the straight snap so that you will snap on to that line if you are within 20 pixels of it.
275.56 In reply to 275.55
Thanks, Michael, Increasing weight is working fine, no need for something else...! Also snap angle is great.
275.57 In reply to 275.56
One other quick note - currently a different way to do a tube shape (a hollow cylinder) is to draw 2 concentric circles and then do extrude. That's probably easier than doing 2 cylinders with booleans since you only have to specify the height once with the extrude way.
When you extrude something you can have curves nested inside other curves - the inside ones become holes during the extrusion.
275.58
Not much time these days to answer to various posts. I've seen a lot of cool suggestions and I'm glad to see that there will be new options for arc 3 points and elliptical arc. I had no time to say that I supported these suggestions before Michael announced they would be in the next beta !!!
The new option for meshing planar surfaces will also be welcome. Not only for further detailing the mesh but I think it will ease the creation of nice UV maps as well. And who knows, maybe Ngons with less points will be easier to import into Modo ! ;-)
The mesh example in the post by Michael looks very similar to what Amapi Pro produces.
Thanks Michael for great reactivity to various requests.
Now, I'd like to second the request of JDK (Jesse) concerning the use of arrow keys to move objects and (more important in my opinion) control points. With an option to set the distance (for example click on arrow key would nudge a point 1/10th of a unit while Shift click would nudge 1/2 or 1 unit...)
Also the suggestion to extrude surfaces along their normals has my support.
Could you implement a "cap ends" function for the Revolve and Rail Revolve tools as you've done for Loft and Sweep ?
And by the way, Michael, what about functions to enable some kind of symmetry modeling ??? Would be cool for extrusions and move functions sometimes...
MoI is really growing fast and in a brilliant manner. Probably the main reason why there are so many jewellers using it is because it is a true gem ! ;-))
275.59
One request that would be nice would be if you could toggle the active view to full screen with the spacebar. In other words if the Front view is active and you hit the spacebar then it would toggle Front View to full screen mode.
It would make it just a hair faster to switch screens in to full mode.
Thanks again for all of your work on this fantastic program!
Richard
275.60 In reply to 275.59
Spacebar is currently Select All / Deselect All
I = Invert Selection
H = Hide Invert selection
Have you the same on your Comput?
EDITED: 24 Jan 2007 by PILOU
275.61 In reply to 275.60
Hi Pilou -
> Space barre is currently Select All / Deselect All
I think these are the custom keyboard shortcuts that you have defined for your computer - other computers are not set up with these keys by default.
275.62 In reply to 275.61
Ok :)
Is it possible to press something for have the list of ShortCut used?
And better a Dialog box for "Input / Change" Key ShortCut?
275.63 In reply to 275.59
Hi Richard,
This is possible in the current version by defining a custom keyboard shortcut.
To do this, close down MoI, then run notepad and open up the moi.ini file, which you can find in this location: C:\Documents and Settings\[your login name]\Application Data\Moi\moi.ini . Note that by default "Application Data" is a hidden folder, but you can just type it and go into it anyway.
Inside the moi.ini file, there is a section labeled [Shortcut Keys]. Add this line to it:
[Shortcut Keys]
Space=script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
Put all that Space= stuff all on one single line.
Make sure to close down moi.exe before editing the moi.ini file.
After you do this, your space bar will put the view under your mouse into full screen mode, or if you are already in full screen mode it will switch to split mode.
Let me know if you have any problems setting this up.
275.64 In reply to 275.62
I do want to have a dialog box for this eventually. This will probably be a little while though.
Right now you can see the list of shortcuts by opening up your moi.ini file.
275.65 In reply to 275.63
Oh, and Petr has listed some other useful scripts you can assign to shortcut keys here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=204.3
275.66
Michael,
Thank you so much :)
I had no idea you could edit the ini file like that *rubs hands together* now I'm of to do some tweaking.
Richard
275.67 In reply to 275.45
> I would like to see the star feature added to the polygon menu.
> I cant count how many times I've used it in rhino.
You mean something like this?
This will be in the next beta.
Now I've got to stop adding stuff for a little bit and go back and finish up the background images... :)
275.68 In reply to 275.67
Stars and construction lines are kind of fun to play with:
275.69 In reply to 275.67
Stars or gears? Maybe gears will be useful too :)
Your stars' drawing remember me http://en.wikipedia.org/wiki/Penrose_tiling :)
and its crazzy Aperiodic pavments with only 2 figures! :D
275.70 In reply to 275.58
Hi Bernard, thanks for the feedback!
This part is now done for the next beta.
But I'm afraid the other ones will have to wait a while...
275.71 In reply to 275.69
Just stars for now. Gears would definitely be useful, but they are a lot more complex with a lot more options needed for real engineering use, so those will have to wait for a while.
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  …  152-157
