MoI - Big Wishlist thread - Post your wishes here
 1-5  6-25  26-45  46-65  66-85  …  146-157
275.26 In reply to 275.24
Arc has Start On End
Circle Start On End or Start End On
Seems stricly the same?
Maybe something useful will be the possibility to move "one" of the 3 points before close the function Circle (or Arc)?
Because when you select "Show Points" you have many points of the "curve circle" (or Arc) !
And move a point of "Show point" of a circle is not the same than move one of the 3 points construction :)
EDITED: 22 Jan 2007 by PILOU
275.27 In reply to 275.24
Please change the 3 point arc, it's hard to set the curvature accurately if you set the mid point as the second step!
Star->end->point on circle would be much better! As you drag the point around, you can easily see the circle you are drawing.
Please change! :)
275.28 In reply to 275.27
Seems reasonable for the circle :)
Maybe less for the arc when you draw in 2D (view Top)
when you search a good form Start On End is better as End is not yet defined :)
Maybe add an icone of choice :)
275.29 In reply to 275.25
Hi Crusoe,
Re: mesher
Can you post an example file of something that is not meshing well for you? That will help me to understand your specific problem.
> There is a option called "Avoid Larger Than", but it seems to have no effect
> in subdividing large flat areas.
There actually isn't any "Avoid Larger Than", but there is a "Divide larger than", and "Avoid smaller than".
Divide larger than is the one that lets you put in a distance and will subdivide lengths larger than this value. So that's the one you want. However, it doesn't do anything to completely flat planar surfaces, it only affects surfaces that are curved in some manner. I suppose I can add in an option to include planes or not if this is causing a problem for you.
Right now you can try the Aspect ratio limit below that - try putting in a value of 4 or 3 in here and see if that helps you, this setting does work with planes.
> Also, could we have a mesher export option to export a model as a mesh that
> represents x-y-z slices of a object? So I could say "Export mesh a mesh using
> 10 slices per x unit, 10 per y unit, and 10 per z unit"? This would give a nice
> regular mesh of tris/quads suitable for zbrush detailing.
Unfortunately this would be extremely difficult for me to code except in a few special cases for stuff like boxes. Any kind of curved surfaces would involve a huge number of intersections of the surface which are slow to calculate.
275.30
My little wish:
1) Like Cinema4D, expand the current view with Central Mouse button;
central again, to put into splitted mode! ;)
2) Great the Pen table movement view, but are great if have the possibility to use same mouse Movement like cinema4D! (into 3d View)
Tnx Michael for this great piece of software! ;)
___________________________________
MrBraun - Moderator www.C4dHotline.it
Cinema4D R10 and MOI of course!
EDITED: 22 Jan 2007 by LORENZO
275.31 In reply to 275.24
add: arc 3pts method
  I think that Start,End,Point method is more useful.
  - I usually know end point or I can find it with a construction lines.
  - When I pick start and end point, the third point influences only an arc radius while with current method the arc radius and point location are still unknown.
  - When I have three explicit points, there is no problem with picking end point first
So if Crusoe begs for an alteration, I join him!
Petr
275.32 In reply to 275.27
I'm also finding that the current settings for the 3 point arc difficult to use.
For me personally, Start>End>Point would be far easier to position correctly within a model.
But I'm only stating this as a complete novice??
regards Colin
I am not agree with you!)
Say you want draw a rosace
You have the circle
Start Arc from anyway on the circle
On = center of the circle
End = somewhere you want on the oposite side folowing on the circle and inspiration
due the design wished : can moving "end" on the circle is an help for the eyes!
So for me Arc 3 points by Start On End is a good thing :)
Maybe Michael can make 2 variantes: one for you, one for moi (me in french) :)
And can move these "3 points" a big help also! (before "validate" Arc function)
(idem for the "3 points" of a circle)
EDITED: 23 Jan 2007 by PILOU
275.34
But you can still draw the rosace using the other method as well.
Pick start
Pick end
Pick "On" point to overlap other "ON" points.
Going in this order makes it easier to use for other things, not just rosace.
275.35 In reply to 275.34
Ok, I have tuned up Arc with 3 points for the next beta.
There is now an option for Style: where you can choose either "Start, End, On" (the new method as requested), or "Start, On, End" (the old method).
The initial default is the new method.
Thanks for all the feedback!
275.36 In reply to 275.35
Cool!
That's avoid war between classics against the moderns :D
You say "Style" : it's applied to Circle also or just Arc?
275.37 In reply to 275.36
Yes, now everyone can be happy! :)
Just Arc - this doesn't really apply to circle since 3 points define just one circle no matter which order they are picked in, there isn't really a start or end point for the circle.
275.38 In reply to 275.37
ok:) And about the move of the 3 "points" before validate function?
275.39 In reply to 275.38
This one is harder - I guess you mean that there would be a "done" button and the command would not exit until you pushed "Done"?
This would be a lot different than every other draw command - for instance should line add another step for "done" and let you move the 2 points for a line before you exit?
This would add an extra step to a lot of commands...
275.40 In reply to 275.39
With the mouse till you don't right clic after the 3third point or clic on another function, 3 points are "visible and movable"
With pen 3 points are "visible and movable" till you don't clic on another function
No need more button !
Just a suggestion :)
Of course yes this need a little more scripting :)
275.41 In reply to 275.40
re: move the 3 points before exiting the command.
I think that eventually this will be covered by history - eventually when there is an object tree available, you should be able to pick the 3pt arc and see that it has a history that it was created by 3 points, and have some way to turn on those points and edit them and have the arc update. That would then behave like you are describing. But it will be quite a while before that is ready.
Right now I don't want to do this since it would require an extra action - either right-click or "done" button, they are much the same. That would be quite a bit different than the other draw tools.
This is not easy to do without having a "done" button, since you may want to select the arc after you draw it. There is no button for going into selection mode, that's normally what the "Done" button is for, to exit the command and then go back into selection mode....
Thank you for the idea though!
275.42
Aren't you glad alot of the interface is written in JScript? ;)
Anyways, I want to thank you for all the hard work. This is a great lil tool.
275.43 In reply to 275.29
So I went in, and tried to set it to a rediculously high mesh level.
Note the large unsubdivided polygens on the guard/hilt. Ideally, it would be great if those large areas got cut up into more quads/tris/ngons. That way I could import into zbrush, and detail it further.
Yeah, maybe the slices idea is too slow, but 'gridding' a flat surface would be great. It should respond to "Avoid larger than", that way I can set the density of the grid.
275.44 In reply to 275.42
Yup! The flexible underpinnings of the UI really help me adapt things and make changes more rapidly than is normally possible.
Thank you!
275.45
I would like to see the star feature added to the polygon menu. I cant count how many times I've used it in rhino.
Drawing a curve on surface would be nice too! There may be a way to do it now, but I havent found it.
Regards,
Ken
Oops, forgot the project command would be real nice too.
EDITED: 23 Jan 2007 by JWLRYMKR
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  …  146-157
