MoI - Big Wishlist thread - Post your wishes here
 1-12  …  113-132  133-152  153-157
275.153 In reply to 275.109
Hello Michael,
Is ScaleArray compatible with V4.0?
275.154 In reply to 275.153
Hi Psygorn,
Yes, I just tested it to verify. Note that the way ScaleArray works you need to include a point object in the objects being arrayed. That is used as the origin of the scaling.
275.155 In reply to 275.154
I had downloaded ScaleArray.zip and then unzipped it. then added "_" at the beginning of the names of "ScaleArray.htm & ScaleArray.js" files then put them in the Command folders.
However, I think I don't know how I should include a point! I know ScaleArray will work after a directional array is made but should I add a point using Draw Curve>More>Point , Because I did and then used ScaleArray but I saw no changes in the objects!
What am I doing wrong?
275.156 In reply to 275.155
Hi Psygorn, did you add just one point after doing the array? If so then that's the problem - you need to add the point in before doing the array and include the point in the array operation as well.
Then select all the arrayed output including the arrayed points and then run ScaleArray.
- MIchael
275.157 In reply to 275.156
Ah ok, Thanks, now it works :)
Show messages:  1-12  …  93-112  113-132  133-152  153-157
