MoI - Big Wishlist thread - Post your wishes here
 1-8  …  109-128  129-148  149-157
275.149 In reply to 275.148
Hi Danny,
> What do you mean, For now at least ?
Well, I mean I probably won't be able to work on stuff for Extend here in v2 since I am trying to wrap it up. But maybe I will be able to make progress later at some point.
Until I have a chance to do something different, using Ctrl+A can make using the current untrim function easier.
275.150 In reply to 275.149
> Well, I mean I probably won't be able to work on stuff for Extend here in v2..........
I hope I didn't come across wanting that feature now, I was actually referring to how you've made Ctrl+A like a chaining function after selecting an edge of a surface,
I thought you had some other ideas on chain selection of curves and edges.
275.151 In reply to 275.150
Hi Danny, no I didn't think it sounded like that, I just wish that I did have time to work on that right now...
Yeah, I do want to have some other tools for that, something like grow a tangent chain off of an initial selection.
Ctrl+A is just meant as a way to grab all edges easily, not so much as a replacement necessarily for directional type chaining, although for some cases they would be equivalent.
French Version of the ScaleArray! :)
http://moiscript.weebly.com/scalearray.html
275.153 In reply to 275.109
Hello Michael,
Is ScaleArray compatible with V4.0?
275.154 In reply to 275.153
Hi Psygorn,
Yes, I just tested it to verify. Note that the way ScaleArray works you need to include a point object in the objects being arrayed. That is used as the origin of the scaling.
275.155 In reply to 275.154
I had downloaded ScaleArray.zip and then unzipped it. then added "_" at the beginning of the names of "ScaleArray.htm & ScaleArray.js" files then put them in the Command folders.
However, I think I don't know how I should include a point! I know ScaleArray will work after a directional array is made but should I add a point using Draw Curve>More>Point , Because I did and then used ScaleArray but I saw no changes in the objects!
What am I doing wrong?
275.156 In reply to 275.155
Hi Psygorn, did you add just one point after doing the array? If so then that's the problem - you need to add the point in before doing the array and include the point in the array operation as well.
Then select all the arrayed output including the arrayed points and then run ScaleArray.
- MIchael
275.157 In reply to 275.156
Ah ok, Thanks, now it works :)
Show messages:  1-8  …  89-108  109-128  129-148  149-157
