Why Won't This Blend?
2743.1
Hello,
Why won't these two curves blend? All it seems to do is create a small loop at the top points. I think this goes back to this massive brain freeze I have with seams, but I cant see any other way to create this shape. Thanks.
2743.2 In reply to 2743.1
Something is missing here!
2743.3 In reply to 2743.2
Hello,
Sorry about that. Here it is.
EDITED: 8 Aug 2024 by OSTEXO
2743.4 In reply to 2743.3
Hi Ostexo,
the blend works on "Edges". Blending curves works in a different way. Draw 2 lines in top view, a bit apart from each other and blend those to see the diff.
2743.5 In reply to 2743.1
Hi OSTexo, yup Burr has the answer there - to fill in an area along the length of a curve, that actually requires a surface edge not just an independent curve object.
The surface is what is used in that case to align the blend surface result.
So for your case here you could extrude each of those curves, then hide or delete the curves, then select the surface edges and then you will be able to get a blend like you want.
Blend also does work on curves, but it creates a blend curve result (not surface result) in an open area between the endpoints of 2 curves, like this:
