Bug :: object properties panel
All  1-4  5-6
2729.5 In reply to 2729.3
Hi Will, yup when I make a pass through the manual at the end of v2 here, I will be putting in all the information on the new functions like this.
2729.6 In reply to 2729.4
Hi Petr,
> Unfortunately? I don't think so. Just good to know
> how to use it :) -Petr
Well, unfortunate in the sense that it can be pretty easily interpreted to be a bug.. :)
The other possible thing to do for that would be to go through and mark every single numeric input for whether it was able to take negative numbers or not, and then it would be possible to use that single minus sign syntax for relative adjustment on the fields that only took positive numbers.
The thing I don't like about that is having different syntax work for different fields, in some sense it is more simple to have only one syntax that works in all situations.
> EDIT: Just another one of the findings... there is "Edit object
> name" dialog window and not flyout menu like for other items
> in the properties panel...
Yup, that's because I made a kind of general purpose "edit the name of something" dialog which may be useful to be re-used in other situations in the future where something needs to let you edit a name label.
A dialog is a little more generally re-usable than a flyout since a flyout doesn't necessarily fit with some things like a multi-stage script.
Show messages: All  1-4  5-6
