Bug :: object properties panel
2729.1
I have noticed some bugs in object properties panel.
1) The object style and size properties entry overlap if there is no name of style.
2) Relative adjustment using negative value (e.g. -1) seems not to work.
By the way, is there any reason why the numeric input flyouts doesn't pop up when clicking on a numeric field in the properties panel to edit the size.
Petr
2729.2 In reply to 2729.1
Hi Petr,
Thanks for reporting this, I've got it fixed up for the next beta.
> seems not to work.
Yes, unfortunately you have to use a double minus (like --1) to do a negative relative adjustment.
That's because the relative adjustment works in a general way on any numeric input field, including ones that can take negative values. If it made a relative adjustment by entering in something like -1, then that would interfere with the ability to input a negative number in some places where that is possible.
For example, draw a rectangle and enter in 5 for the width.
Now you can go to the width again and enter --1 to make a relative adjustment or you can enter in -1 which is a valid number of its own to have there.
It's also allowed to use ++ for a relative addition if that helps to remember the syntax.
Well, there's a few things for that.
First, it just felt like that would be used by people using typed in values a lot...
Also those controls are customized to have some special properties on them, like being able to use variables like x or z (any of x, y, z, l, h, r, d) in expressions, so that required a custom control which was easiest to set up as just a type-in only one.
Also since that panel is pretty small it kind of seemed a bit odd to have the flyout come out of there.
Those fields are also modified to have an extra number of decimal points precision displayed in them.
2729.3 In reply to 2729.2
Michael, when you update the manual for v2, please remember to put all these kinds of tidbits in there!
There's so many intricate details within MoI that fear I'll forget a lot of these power techniques!
(Not to mention half I don't know! :-O )
-Will
2729.4 In reply to 2729.2
Hi Michael, thanks for explaining it.
Unfortunately? I don't think so. Just good to know how to use it :) -Petr
EDIT: Just another one of the findings... there is "Edit object name" dialog window and not flyout menu like for other items in the properties panel...
EDITED: 26 Jun 2009 by TYGLIK
2729.5 In reply to 2729.3
Hi Will, yup when I make a pass through the manual at the end of v2 here, I will be putting in all the information on the new functions like this.
2729.6 In reply to 2729.4
Hi Petr,
Well, unfortunate in the sense that it can be pretty easily interpreted to be a bug.. :)
The other possible thing to do for that would be to go through and mark every single numeric input for whether it was able to take negative numbers or not, and then it would be possible to use that single minus sign syntax for relative adjustment on the fields that only took positive numbers.
The thing I don't like about that is having different syntax work for different fields, in some sense it is more simple to have only one syntax that works in all situations.
Yup, that's because I made a kind of general purpose "edit the name of something" dialog which may be useful to be re-used in other situations in the future where something needs to let you edit a name label.
A dialog is a little more generally re-usable than a flyout since a flyout doesn't necessarily fit with some things like a multi-stage script.
