Mesh looks crimped, surface separating from edge?
All  1-6  7-8
2725.7 In reply to 2725.6
Hi Leonard, no problem, I'm glad that helped!
One other note - if you are going to be frequently saving to an OBJ file just for testing what the mesh is going to look like, it can be handy to set up a keyboard shortcut for doing a kind of "dummy save" so you can see the export meshing results.
To do that, go to Options / Shortcut keys, and add in a new entry. For the command put in this:
SaveAs c:\test.obj
Then whenever you hit that key it will go through the process of saving to a file c:\test.obj, and will pop up the export meshing options dialog right away, without needing to deal with the file name dialog. Then cancel out of the mesh dialog after you see what the mesh looks like.
2725.8 In reply to 2725.7
Sweet! Thanks for the extra tip, Michael and I will set up that shortcut. -L.
Show messages: All  1-6  7-8
