Could you update moi.idl?
 1-11  12-26
2715.12 In reply to 2715.10
Hi Dave, also if you want to get oleview working, possibly this download will do the trick:
http://www.microsoft.com/DOWNLOADS/details.aspx?FamilyID=5233b70d-d9b2-4cb5-aeb6-45664be858b6&displaylang=en
That seems to have an installer so it should have the dependent DLLs included in there I would think.
2715.13 In reply to 2715.12
Michael,
Thanks for the moi.idl file!
I just found out what the problem was with oleview.exe...duh! Under Vista/Windows 7 you need to run it as administrator (otherwise the RegisterDllServer call fails). I love cryptic error messages! I was getting the same errors on my laptop running Windows 7 RTM,so I began fiddling with it again, and running as administrator did the trick...
- Dave Morrill
2715.14 In reply to 2715.12
Michael,
This is the result of my automated analysis of the changes from the Jun_23 beta to the Aug_08 beta:
Deleted method: GeomObject.getHighAccuracyBoundingBox
Added method: BoundingBox.clear
Added method: GeometryDatabase.selectLastCreated
Added method: PointPicker.orientedptframe
Added method: Settings.objExportWriteMaterialAssignments
Added method: Settings.meshExportCombineSameNamedObjects
Added method: Settings.editIniFile
Added method: Settings.getIniPath
Added method: UI.alert
Added method: VectorMath.createBoundingBox
Added method: View.specularBrightness
Added method: View.customFillLightLevel
Added method: View.edgeFixedColor
Added method: View.lightingStyle
Added method: View.surfaceFixedColor
Added method: View.metallicLighting
Added method: View.edgeColorMode
Added method: View.customKeyLightLevel
Added method: View.fixedLightPositions
Added method: View.specularFocusSize
Added method: View.specularHighlights
Added method: View.surfaceColorMode
Since this is my first "delta" build, just as a sanity check, does this look about right to you?
- Dave Morrill
2715.15 In reply to 2715.14
Hi Dave, yup that seems to be right to me.
The deleted method (GeomObject.getHighAccuracyBoundingBox) was one that was not working correctly and was crashing, so I figured that nothing could have been using it.
I switched its functionality to be included with the regular getBoundingBox() method, there is now a new optional parameter that can be passed in to get the high accuracy bounding box.
The regular bounding box method uses the display mesh to get the bounding box. The "high accuracy" one uses numeric methods that analyzes the NURBS shapes directly which is slower but also more accurate.
2715.16 In reply to 2715.15
Sorry Guys,
BTW, whats the goal of this discussion ?
In another word, Whats Dave try to achieve ?
2715.17 In reply to 2715.16
Dave is creating documentation of MoI's Scripting interface.
2715.18 In reply to 2715.17
2715.19 In reply to 2715.18
Hi Burr,
Then what is the benefit for end user ?
Sorry scripting is not my world.
2715.20 In reply to 2715.15
Michael,
OK, great! Thanks for the explanation about the deleted method. Seeing something disappear from the API this morning is what triggered me to add the extra logic to the script to detect the specific API changes.
I'll add the information about the difference between the low/high precision flavors of bounding box to the doc as well...
- Dave Morrill
2715.21 In reply to 2715.19
The benefit for the end user is indirect, but potentially very large.
If you look at how Michael built MoI, it really consists of two main layers:
1) A core C++ class library that implements all of the low-level NURBS functions, 3D graphics, etc. Most of the functionality of this powerful library is exposed via COM interfaces and a Javascript API to the high-level user interface layer that you see while using MoI.
2) The high-level user interface layer of MoI is (in some sense) a very specialized version of the standard Internet Explorer web browser extended with some custom controls (such as the 3D viewports and the fly-out menu controls). All of this functionality is implemented as a series of standard web pages, using HTML, CSS, Javascript and the custom MoI Javascript API.
And that's what this discussion is all about. The standard MoI user interface is really just a set of web pages that William wrote, using HTML (well-documented), CSS (well-documented), Javascript (well-documented) and the custom Javascript API to access the powerful C++ MoI class library (completely undocumented).
What I am attempting to do is to document the MoI Javascript API. With that available, any motivated MoI user with some basic Web and Javascript skills should be able to extend or modify MoI in any number of ways, which eventually translates into more cool MoI functions and capabilities for every MoI user. And perhaps most importantly (in my mind at least), it empowers the MoI user community to accomplish this without having to request Michael to add yet another item to his ever-growing ToDo list :-) . But note that having this new documentation will not allow users to implement any new feature they want. Some features require enhancements to the core C++ library, which practically speaking, only Michael can do. But that still leaves a lot of room for creating all kinds of new user-implemented features for MoI.
I hope this explanation helped...
EDITED: 14 Sep 2009 by DMORRILL
2715.22 In reply to 2715.19
Anis,
The benefit is for those that want to script MoI. If you dont want to script MoI then it wont be of interest to you.
You've seen Michael write scripts for people to do special things or automate a process. This documentation will be for those that want to figure out and write things for there own purposes or other people.
So even if you dont know javascript, eventually there will probably be quite a gathering of specialized scripts that one could browse and choose from.
If I became very good at it, I could even take requests and write custom plugins for MoI and charge money for them!
2715.23 In reply to 2715.22
William? I thought we owe this/MoI to Michael ;)
Cheers,
. Diego .
2715.24 In reply to 2715.23
Just checking to see if anyone is paying attention...you pass :-)
- Dave Morrill
2715.25 In reply to 2715.22
Hi Burr,
But you need to get MoI SDK before it will happen ? Isn it ?
2715.26 In reply to 2715.25
Hi Anis,
You would need an SDK to do something very completely different from anything currently in MoI, like make a T-splines plugin or complex things like that which do a lot of unique low level processing.
But even without a C++ SDK you can use scripting to create plug-ins right now that work with the existing tools in MoI but package them together in different ways.
There is a lot that can be done with scripting, there are several example plug-ins that you can look at already which are collected on Petr's page here:
http://kyticka.webzdarma.cz/3d/moi/
One reason that scripting works well in MoI is that it is not just something kind of "tacked on" to MoI, it is used for all of MoI's regular functions. For example commands such as the line command, curve command, etc... all have a script component to them.
Show messages:  1-11  12-26
