Icons without text?
All  1-3  4-8
2708.4 In reply to 2708.2
All works fine except only this little thing for Circle and Arc circle
Curiously the last icons don't take place at the end of the line!
Even Margin:3px; exists or not, smaller bigger or not ! (maybe there is an artificial trick to make? )
So not a big drama :) That is very Zen!
EDITED: 22 Jun 2009 by PILOU
2708.5 In reply to 2708.4
Yes, that's a consequence of the side pane becoming narrower in width with the text removed.
Those "command set" items are set to wrap to take up multiple lines if they do not fit within the available width.
2708.6 In reply to 2708.5
PS In this Zen Attitude, maybe "Draw Curve", "Draw Solid" etc can be also an icon! :)
2708.7 In reply to 2708.6
That one can't be done with just a simple CSS adjustment though, since there are not currently any image files set up for those.
But if you'd like to give it a try, you would want to first create the PNG image files for those, then you would modify the file SidePane.htm and remove the text tags (like <moi:Text textid="Draw curve tab"/>) and replace them with <img> tags instead.
But it can tend to be difficult to make good icons for categories, text is often clearer for that level of organization.
2708.8 In reply to 2708.7
<But if you'd like to give it a try
Maybe I will make a try :)
Show messages: All  1-3  4-8
