Top 10 reasons for buying MoI...
 1-17  18-22
2704.18 In reply to 2704.17
the original model was less funny =O)
EDITED: 3 Dec 2015 by PAQ
2704.19 In reply to 2704.16
Hi Jason, yeah like PaQ shows you can use the "Divide larger than" function in MoI's exporter to ensure that large polygons are diced up into smaller evenly sized pieces.
That can make a result that should be suitable for non-rigid-body type animations without necessarily needing to retopologize.
Certainly if you have a very specific kind of animation where you want one individual piece to move in a certain way it could be a good idea to retopologize that area though...
2704.20 In reply to 2704.19
Good point, good to try first without doing topo again.
What I like though is that MoI is getting to be an artists tool, so keeping in mind that MoI can play nice with modo, 3DC, SILO is a good thing.
- Jason
http://www.jasedesign.com http://www.nurbsandpolys.com http://www.cgpipeline.com
2704.21 In reply to 2704.13
> Hi Dave, just a note on this part...
Thanks for the detailed explanation, Michael!
I'm definitely switching over to using .lwo format from now on...
Dave Morrill
2704.22 In reply to 2704.14
> So I'm still doing an geometry>poly>align when importing .lwo object ... it works as a double flip you descibe, but it's an 'autmaic' way
so it will resolve normal problem on area you don't always notice at first sight. (Can be frustrating to discover a wrong poly after an hires rendering of 4 hours for exemple).
Thanks for that tip, PaQ! I think I had tried 'align' on a Bonzai 3D model when I was evaluating it (they tend to produce lots of flipped polys all over the mesh), but it didn't seem to have any effect on the flipped polys. It's good to know that it fixes the problems if and when they occur in a MoI import.
Is there any trick to using 'align'? I think when I tried it on the B3D mesh I did not have any geometry selected. That is, since nothing was selected, I assumed it would work on the entire mesh in this case. Is that the right way to use it, or should I have something selected before using it?
Dave Morrill
Show messages:  1-17  18-22
