joint?
All  1-5  6-17
2691.6 In reply to 2691.5
> And other thing: how do make for know that some
> curves or volumes are overlaped?
For surfaces, you can see that there is an adjacent face there because it will be a shaded-in area rather than an empty area.
So for example in your original model you posted, you had a surface here:
You can see that there is a surface there due to the shaded filled in area rather than an empty area... I deleted those surfaces in the updated file that I posted, so that it was easier for you to select the edge of the surface you wanted to blend with.
If you have a curve overlapping a surface edge, you can tell that by moving the mouse over top of it with the surface not selected - normally to select an edge you must select the surface first. If you see something that looks like an edge being highlighted when you move the mouse over it, but you have not selected the surface, then that is how you can see that there is a generator curve there.
2691.7 In reply to 2691.6
Ok I see that was my errors and can remake your repair :)
So why curves generator have the same color (selected or not) than the other curves by default?
It will be not more easy to distinguish them?
2691.8 In reply to 2691.7
I've tried to avoid having too many things of different colors by default - if you don't understand what the colors mean, it can be confusing.
Also too many default colors then becomes incompatible with using a colorizing system as user-choice method of organizing objects.
So there can be some bad effects from doing that.
My best suggestion currently is that you should try and "clean" up your generator curves after you have created a surface from them. They are generally selected after you have created a surface and that is a good time to hide or delete them to get them out of the way.
2691.9 In reply to 2691.8
< you should try and "clean" up your generator curves after you have created
yes :)
A little question again : generator curves are not in the browser?
EDITED: 16 Jun 2009 by PILOU
2691.10 In reply to 2691.9
> A little question a gain : generator curves are not in the browser?
Yes, they are just regular objects so they are in the browser the same as any object.
One easy way to hide them all with the browser is to go to Types / Curves and click the eye icon on that entry to hide all curve objects.
2691.11 In reply to 2691.10
Thx for all these explanations!
About Blend again
cylinder and a box : works with one segment, not more
Does normaly same numbers of segments in each object to blend?
Box and box : one by one yes, but not 4 *4 (4 segments of a facet)
EDITED: 19 Jun 2009 by PILOU
2691.13 In reply to 2691.12
oooops!
2691.14 In reply to 2691.12
Yes, that's currently a limitation of Blend, that you can only do it between 2 edges at a time.
I'd like to remove this limitation in the future, but for now to get a result between a cylinder and a box like you show there, you would want to select the cylinder's edge curve and use the Trim command on it with "Add trim points" to break that edge into 4 sub edges, then you would have a compatible edge structure on the end of the cylinder for blending to the box.
2691.15 In reply to 2691.13
Joint!
2691.16 In reply to 2691.15
Joint!!!!
2691.17 In reply to 2691.16
Joint!!!
Show messages: All  1-5  6-17
