joint?
All  1-10  11-17
2691.11 In reply to 2691.10
Thx for all these explanations!
About Blend again
cylinder and a box : works with one segment, not more
Does normaly same numbers of segments in each object to blend?
Box and box : one by one yes, but not 4 *4 (4 segments of a facet)
EDITED: 19 Jun 2009 by PILOU
2691.13 In reply to 2691.12
oooops!
2691.14 In reply to 2691.12
Yes, that's currently a limitation of Blend, that you can only do it between 2 edges at a time.
I'd like to remove this limitation in the future, but for now to get a result between a cylinder and a box like you show there, you would want to select the cylinder's edge curve and use the Trim command on it with "Add trim points" to break that edge into 4 sub edges, then you would have a compatible edge structure on the end of the cylinder for blending to the box.
2691.15 In reply to 2691.13
Joint!
2691.16 In reply to 2691.15
Joint!!!!
2691.17 In reply to 2691.16
Joint!!!
Show messages: All  1-10  11-17
