the real time commands
2682.1
Hello Michael !
I have got a note that Moi has real time command I mean that for example If I use the extrude command the line start to raise (suddenly after I push the command icon and wait to specify an value) Unfortunately I have got 1000 lines what I want to extrude at the same time because to extrude each line takes a long time. But currently it takes same time because moi try to extrude all line but my computer doesnt bearing this performance. What about? If the extrude command would be an static command ( and of course real time as well ) maybe it would work better and faster.
2682.2 In reply to 2682.1
However It is not so important because I explored when I stay on command area (right side) the lines keep the positions.
2682.3 In reply to 2682.1
Hi andras, I think it would probably not be good to change it always to be a static command, because people who are working on a more typical amount of curves (like extruding only 2-3 curve at once) get a nice benefit from having the full feedback.
One thing that I have thought about doing is to switch the extrude into a lighter "wireframe" kind of feedback when the number of curves being handled was large.
Currently though if the mouse interaction is not going fast enough, you may want to enter in some numbers in the "Distance" input instead of using the mouse inside the viewport.
2682.4 In reply to 2682.3
yes, yes of course
