About Scaling Rail
All  1-6  7-10
2681.7 In reply to 2681.6
> Ps Not possibility to have the Rail Scaling only limited of
> the "upper" half side of the volume?
> (don't want the bottom section follow the Rail Scaling)
Not with a scaling rail - it works by applying a scale transformation on the profiles, which does not easily allow for that kind of a "partial" scale in a general way.
But if I understand you correctly, you can get that kind of a shape by using a 2-rail sweep instead of using a scaling rail.
That would be a profile and rails like this:
Then when you do the sweep, select both of those as sweep rails at the rail selection prompt, instead of picking one as a scaling rail later. With both of those as sweep rails, the profiles will slide along the 2 rails which gives this kind of a result:
2681.8 In reply to 2681.7
yes but as my first volume is a 2 rails sweep (so Horizontal asymmetric side) maybe I can make that if the Rail Scale don't make half section
(not so a big deal :)
EDITED: 13 Jun 2009 by PILOU
2681.9 In reply to 2681.8
Hi Pilou, also when you start wanting to get a lot of control in many different areas like this, you may want to switch to the Network command instead. There you can add in a larger number of profiles.
But also it looks like assembling your object in halves works for your case too?
2681.10 In reply to 2681.9
yes assembling works fine!
I was afraid that horizontal section shoud be different after the rail scaling but all works fine :)
Show messages: All  1-6  7-10
