Diff problem
All  1-4  5-7
268.5 In reply to 268.4
> also a "solidify" command as an option would be great.
As Petr mentioned, this command does currently exist as the Construct/Planar command. If you have an object with planar open ends, you can select the object and run Construct/Planar and it will fill in the holes with planar surfaces which will solidify the object.
Construct/Planar also does another function which is to build a flat surface from a set of planar curves, which it will do if curves are selected instead of surfaces when you run it.
268.6
Just did a test and understood what you're saying, thanks Michael, Petr, everything is ok.
268.7 In reply to 268.6
For the next beta, I have tuned this up a bit so that loft and sweep have a new "cap ends" option, which shows up if you have planar closed profile curves. So with this loft and sweep can produce a solid directly without any extra steps.
Show messages: All  1-4  5-7
