Diff problem
All  1-2  3-7
268.3 In reply to 268.2
Yes for the time being the booleans tend to get a little confused with open (non-solid) objects.
Until I get a chance to tune this up you should either solidify the object like Petr mentioned, or an alternative to that is to use the Edit/Trim command to cut the objects with each other and leave the pieces behind, then do an Edit/Join to join the pieces together.
268.4
Thanks, I didn't think of that.
Michael, it would be nice to fix this, also a "solidify" command as an option would be great. I guess this kind of masses are ment to be solid, not a rectangular tube. If I wanted to make an arc beam for example I would use a rectangular or similar profile but I would like the result to be a solid, not a tube. So I guess this is a must.
EDITED: 5 Jan 2007 by JTB
268.5 In reply to 268.4
As Petr mentioned, this command does currently exist as the Construct/Planar command. If you have an object with planar open ends, you can select the object and run Construct/Planar and it will fill in the holes with planar surfaces which will solidify the object.
Construct/Planar also does another function which is to build a flat surface from a set of planar curves, which it will do if curves are selected instead of surfaces when you run it.
268.6
Just did a test and understood what you're saying, thanks Michael, Petr, everything is ok.
268.7 In reply to 268.6
For the next beta, I have tuned this up a bit so that loft and sweep have a new "cap ends" option, which shows up if you have planar closed profile curves. So with this loft and sweep can produce a solid directly without any extra steps.
Show messages: All  1-2  3-7
