3D Coat v3 released
 1-15  16-35  36-38
2677.36 In reply to 2677.35
Hi Will,
> The biggest thing I've been waiting for is MoI's
> export of surface assignments!
That's actually what I've been working on all this week... It's still in progress but it is looking good!
There will be an update to use both object names and style assignments.
You'll be able to control clustering of mesh output by having the same name on multiple objects. Like if you assign the same name to several objects, when you export to OBJ they will get clustered as one mesh object in the OBJ file, or as one mesh layer in an LWO file.
Then style assignments come through as material assignments in OBJ, or as surface assignments in LWO.
2677.37
Not 3dcoat related but still on topic IMO.
:exports from rhino. obj, without chamfer and in Mudbox refine surface with subdivide selection:
also Tom Finnigan (tsplines founder) said
(I'm working on a T-Spline to SubD converter, which should work great with mudbox. It's still in an early state, but should be helpful.
I'm currently working on improving performance in 2.1, but I think I should be able to get it into 2.1 as well.
In the meantime, Juan's suggestion will work pretty well.)
http://www.tsplines.com/forum/viewtopic.php?f=9&t=29265
EDITED: 22 Oct 2010 by NEO
2677.38 In reply to 2677.37
As 3d Coat import OBJ absolutly no problem to import OBJ object (ngones) from Moi and tranform it in Voxels for crazzy images!
(here "voxels" (not polygons) Conceptual image of course :)
EDITED: 27 Jun 2009 by PILOU
Show messages:  1-15  16-35  36-38
