3D Coat v3 released
 1-5  6-25  26-38
2677.26 In reply to 2677.24
>What is it that you're trying to accomplish with all these things?
Are You Being Sarcastic? If not here we go.
1st. workflow (Graphite) & 2nd. workflow (meshlab) was more like a tip to whom wants to convert tris to quads.
I do build physical prototypes which then I scan after that I refine the mesh with Graphite or meshlab for further use in ZBrush, Modo etc....(depends the nature of the project).
3rd workflow. Well better show these images by yolk than writing an essay. you can see most of the workflow I was describing earlier.
quadrangulate voxel sculpting.
Converted to Nurbs with tsplines
imported into solidworks, shelled (wall thickness) and groove added.
Now for "render friendly" output, Modo 401 will have a solidWorks importer. (but I'm skeptical about the mesh quality. I imagine the mesh that is saved with the SW file for screen display will be what 401 Imports. But this is still a nasty STL like mesh.)...time will show.
EDITED: 22 Oct 2010 by NEO
2677.27 In reply to 2677.19
"If you know that you want to have a light sub-d cage + displacement map result out of ZBrush, then you would not want to use a MoI model to go into ZBrush since you won't get that kind of a result out the other end.
But if you know that you want to have a dense geometry final result, then it can work fine. You'll kind of want to watch how much subdivision you do so it doesn't get too huge with this method though. But it is feasible to add embossing detail to a basic object while keeping things more like 100,000 to 300,000 polygons rather than in the millions."
Hi Michael, I guess this is rhetorical (until I try it for myself), but couldn't I use the hi-poly export from MoI into ZBrush generate the normal/displacement maps and then using a seperate, clean MoI ngon export use that as the low poly base object and just load up the paint & displace maps?
Or would I need the low-poly model in there as well as a part of the displacement process? (I believe that's (unfortunately) the case since I think it needs the level 0 base to refer to for the map generation...)
I also don't now if you can use normal/displace maps from a all tris model onto an ngon topology either.
Just asking, being that I've never attempted to generate normal/displacement maps from my models yet...
Using hi / lo MoI exports would be fine - my probs have always been just getting the models into ZBrush in the first place!
-Will
PS - Thinking a bit further - the normals/displacements would come from the initial tris input vs the displacements and additions I add to the model within ZBrush.
The question then is can I project those maps back onto an ngon version of the model??
2677.28
@Neo
I did a lot a test in that area too, but I give up :)
The solidworks wall thickness looks amazing Oo
@WillBellJr
Normals map and diplace are really different.
You can 'bake' an high res model over a lowres one. N-gones should not be a problem, but I never tried that.
You can use a software like x-normal (http://www.xnormal.net/1.aspx), where you can import a low res object, an hires one, and transfer the details as a normal map.
However, I'm not sure if x-normal will load the MoI .obj with the right vertex normals info. If not, then the result will be really bad.
More less every 3d package can do this normal transfer now, the only problem is to import the high-res model. (x-normal is really optimized to import huge highres models).
For the displacement it's an other story, because your base mesh has to be ready to be subdivided with a clarmull-clark kind algo. So you really have to prepare this base mesh carefully (-> sds/poly modeler).
You can for example use 3dcoat for this job too, importing your huge moi mesh, rebuild a new base one with the retopology tools, and then bake the details has displacement map.
2677.29
@Pilou
The decimate tool looks cool ... but ... I need to see how the wireframes look before doing a party.
All the existing decimate solution create ugly mesh, topology speaking, the result if visualy perfect, but it's not the kind of mesh you can use for a character setup.
But maybe they have develop a magic one :)
>> Hi PaQ, just one thing to keep in mind is that not everyone uses ZBrush for exporting to a rendering program - some people want to generate STL data to produce a physical model.
Hi Michael, indeed, I didn't think about that when looking at the sofa example.
2677.30 In reply to 2677.29
Waiting your result about Decimation master :)
2677.31 In reply to 2677.26
Hi neo,
No, I really didn't understand what your goal was for all of this.
I mean, in some aspects it is kind of like trying to put a square peg into a round hole...
If your goal is to get the final output into SolidWorks, then that makes more sense to want to do these kinds of steps - I didn't know that was your final goal until your new message here though!
So does that final goal of export to SolidWorks also apply to what you wanted to do with that couch example you posted previously?
With that one you still may be better off starting with a Sub-d modeler and making the general folds and ripples in it by manipulating the sub-d point cage. Then you bring that into t-splines and convert it to NURBS there. Right now that seems to be the main workflow for that kind of a thing.
But that quadrangulate result you show after voxel sculpting is looking pretty good, that looks like it may be promising!
The nice thing about that voxel method is that it should not be sensitive to what you use as the starting shape - whether it is initial sub-d data or initial CAD data exported from MoI it should not make any particular difference because the final result is extracted from the voxel structure.
2677.32 In reply to 2677.27
Hi Will,
I don't really know enough about the specifics to give you a good answer on this one.
It all depends on how dependent those mechanisms happen to be on working on sub-d levels rather than dealing with geometry directly.
From PaQ's reply it sounds like you would be ok to generate a normal map with this kind of method, but maybe the workflow of how displacement maps are set up to be used are more integrated into relying on the sub-d refinement process and so would not work for this.
2677.33 In reply to 2677.31
yup that's me, a designer not following the crowd...)
It has a dual purpose really.
a) create manufacturable data (in some cases as shown on example above...)
b) use as much of that data possible to create marketing material (photo real renderings etc.)
Correct and that is what I have been doing all along. BUT I fund it counterproductive. (remodel just for the sake to get a "render friendly" output)
THERE FOR STILL IN SEARCH FOR THAT NEXT HYBRID.
The nice thing about that voxel method is that it should not be sensitive to what you use as the starting shape - whether it is initial sub-d data or initial CAD data exported from MoI it should not make any particular difference because the final result is extracted from the voxel structure..
Indeed looks like it may be promising! Also I must say Michael Just your mesher alone has made a big difference...
All I see is Michael Gibson, Matthew Sederberg(tsplins) and Andrew Shpagin(3d-coat) each one holding a piece of the Rosetta Stone...) just put them together and we may have the answer to all questions.
EDITED: 11 Jun 2009 by NEO
2677.34 In reply to 2677.33
I have yet translated two of these trio maybe I will ask the third :D
Thx for the idea :)
2677.35 In reply to 2677.28
"@WillBellJr
For the displacement it's an other story, because your base mesh has to be ready to be subdivided with a clarmull-clark kind algo. So you really have to prepare this base mesh carefully (-> sds/poly modeler)."
Hi PaQ, yes, I realize the normals and displacements are different, I just lost track of the fact that for displacements, you need to be able to dynamically subdivide the model as you're working - so ngons from MoI at that point wouldn't work all that well.
I see however that I am able to get my models into ZBrush now using this high-tri export technique.
Thing is now, I have to reacquaint myself with ZBrush again since it has sat dormant, and out of my workflow for a while. :-P
With 3D Coat, the pixel painting import works fine also - I'm just waiting to see now whatelse ZBrush 4 is going to bring to the table.
The biggest thing I've been waiting for is MoI's export of surface assignments!
-Will
2677.36 In reply to 2677.35
Hi Will,
That's actually what I've been working on all this week... It's still in progress but it is looking good!
There will be an update to use both object names and style assignments.
You'll be able to control clustering of mesh output by having the same name on multiple objects. Like if you assign the same name to several objects, when you export to OBJ they will get clustered as one mesh object in the OBJ file, or as one mesh layer in an LWO file.
Then style assignments come through as material assignments in OBJ, or as surface assignments in LWO.
2677.37
Not 3dcoat related but still on topic IMO.
:exports from rhino. obj, without chamfer and in Mudbox refine surface with subdivide selection:
also Tom Finnigan (tsplines founder) said
(I'm working on a T-Spline to SubD converter, which should work great with mudbox. It's still in an early state, but should be helpful.
I'm currently working on improving performance in 2.1, but I think I should be able to get it into 2.1 as well.
In the meantime, Juan's suggestion will work pretty well.)
http://www.tsplines.com/forum/viewtopic.php?f=9&t=29265
2677.38 In reply to 2677.37
As 3d Coat import OBJ absolutly no problem to import OBJ object (ngones) from Moi and tranform it in Voxels for crazzy images!
(here "voxels" (not polygons) Conceptual image of course :)
EDITED: 27 Jun 2009 by PILOU
Show messages:  1-5  6-25  26-38
