MOI TO OBJ TO 3DS CONVERSION
All  1-3  4-6
2675.4 In reply to 2675.3
MoI V2 is far better than V1 in many ways and you will be hard pressed to mention "Bug". You would not be disappointed if you purchased MoI now and used the V2 beta. FYI.
2675.5 In reply to 2675.3
There are still vertex normal problems with the .fbx export when using some external renderer inside max, like maxwell for example.
That's said it's not MoI fault, as everything is rendering perfectly with the scanline engine or mental ray.
2675.6
Hi again
Thanks to Michael, PaQ and Burrman for your feedback and helpful advice... I will have to get back on the program and test the settings as advised.... I will send an update on the progress in the next few days!
Thanks again Michael; in response to your question, the Poly Count is an important factor because a lot of the assets are mostly part of larger worked-up scenes, a lot of the time there are even multiple models of a few different objects at any one time (amongst others) so we can not afford to accumulate intense Poly volume and risk colossal render times or even crashes. That's why I'm looking for a clever modelling program that will be efficient in our work-flow.... if all goes well then of course MoI will be a very likely contestant to win..... I'll keep you posted!
Thanks!
Z
Show messages: All  1-3  4-6
