Import point file script (Windows 7)
 1-4  5-22
2638.5 In reply to 2638.3
Hi George - hmmm that is rather odd. Maybe somehow the script library for the "FileSystemObject" which that command uses did not get configured properly on your Windows7 installation.
Try running the following from a command prompt (or Start/run):
regsvr32 scrrun.dll
Another possibility may be if you are running some kind of anti-virus system that may be blocking access to that particular library since it can be considered a security sensitive thing since it gives scripts access to files. You may try temporarily disabling your virus checker or see if there is a way you can configure it to allow a script running inside of MoI.exe to be allowed access.
Please let me know if none of these things help any and I will try to look into it some more.
2638.6 In reply to 2638.5
I am sorry for the delayed answer. I tried your suggestion running as administrator regsvr32 scrrun.dll and I get the message that DllRegisterServer in scrrun.dll was successful, but when I tried from MoI to run ImportPointFile I got the same message as before. I don't use any Symantec Antivirus, only Avira AV Free Version and Windows Defender.
Regards,
George
2638.7 In reply to 2638.6
Hi George - I think I see what the problem is now.
The particular method that script uses to show the "get filename to open" dialog is apparently not available on Windows Vista or higher.
For the next v2 MoI beta I'll add in a function inside of MoI which the script can call to handle this so that it will not need to be dependent on the system component that for whatever reason is not available in newer Windows releases.
2638.8 In reply to 2638.7
Thank you Michael
2638.9 In reply to 2638.8
Hi George, I have this tuned up now for the next v2 beta release.
Once the next release is out I will also need to post an update here with a slight modification to the import points command to use the new file dialog method, then it should work on Windows 7 after that, at least I hope so!
I should have the new v2 beta out at the end of this week I think.
2638.10 In reply to 2638.9
Hi Michael....
Hope it will release as your plan ( end of this week ).
Cant wait it Michael.... :)
Thank You ~~~ !!!
2638.11 In reply to 2638.9
Thank you very much. I think we will have a very promising weekend with next Beta.
Regards,
George
2638.12 In reply to 2638.11
Not ready yet.... :(
Maybe tomorrow.... !!!
2638.13 In reply to 2638.12
Hi Anis - it's very close, but the last couple of details may take until tomorrow.
2638.14 In reply to 2638.13
Hi Michael.....
As I thought before.
Your favorite date is 21, isnt it ?
I will download it tomorrow.
One of my concern is ability to read layer from iges.
Thanks !!!
2638.15 In reply to 2638.14
Hi Anis,
Actually, that was one of the last remaining things for styles that I did not have finished yet. But I'm adding it in now as the final thing to do before releasing the beta, I should have it ready today.
2638.16 In reply to 2638.14
Hi Anis, I was able to add in transfer of layers/styles/levels to and from IGES files, and there is now a new beta posted that includes it: http://moi3d.com/beta.htm
Please let me know how the updated IGES transfer works for you.
2638.17 In reply to 2638.11
Hi George - getting back to the Import point file script not working on Windows 7.
I've got a new v2 beta posted (http://moi3d.com/beta.htm), and I think this one will now allow for this script to be updated to work with Windows 7.
I've attached the updated script file to this message. This updated version will only work with MoI v2 (Jun-20 version or later) and not with MoI v1.
I do not have Windows 7 over here though, so I'm not 100% sure - please let me know how it works for you. But hopefully it should get it working.
2638.18 In reply to 2638.17
ImportPointFile Update works fine in the new Beta 20 Jun 09 in Windows 7 x32.
Thank you,
Regards,
George
2638.19 In reply to 2638.16
Hi Michael....
The iges layers importer work very well.
Below is the screen capture and the file size comparison :
2638.20 In reply to 2638.19
Hi Michael...
Today color can be apply to curve, line and edge.
Have you a plan apply color on surface in the V2 ?
Wish the best for you and MoI :)
2638.21 In reply to 2638.18
Hi George,
Great, thanks for testing it!
2638.22 In reply to 2638.19
Hi Anis,
Yes, that's the last part I need to work on related to Styles before that area will be complete for v2.
I should be focusing on that shortly.
Show messages:  1-4  5-22
