Move object by xyz coordinate ?
 1-7  8-21
2629.8 In reply to 2629.1
Hi Anis,
you asked:
> How to move object by input XYZ coordinate.
You can use the "Move" command (in the Transform tools) for moving objects in that way, here is a quick demo for example of moving a line so that its endpoint is exactly at coordinate value 2.1,2.1
Here are the steps:
Select the object you wish to move.
Now run the Transform / Move command.
Click the base point - this is the point that you wish to relocate to a new position.
Now enter your target point (either click it or type in a value) - this is the new location that you want to use.
2629.9 In reply to 2629.7
Actually its not select, change number. Its more like this:
Select selection tool, Select object, click in "X" field and change number, hit tab key and change next number, hit enter.
And what are you moving when you do this anyway? Some arbitrary point in space within your object?
EDITED: 12 May 2009 by BURRMAN
2629.10 In reply to 2629.2
Hi igor,
> but I believe it should better show selected object(point) coordinates
Objects are usually constructed out of a multitude of different points, in the general case there is not just one special point that defines an object.
For example, which point would you display for this object:
> It is a common practice for high precision apps to have these
> input fields for each coordinate (see illustrator or 3ds!).
Actually the most commonly used application for high precision drafting is AutoCAD, which does not have separate input fields.
There are a lot of advantages to a single "command-line" input field which would be lost with a separate entry for each coordinate.
- Entering a single "0" <enter> as a shortcut for 0,0,0 would be lost.
- Entering just x and y coordinates (like 5,3) and being able to leave out z would be lost.
- Being able to enter different formats than cartesian like polar coordinates (for example 5<45 means polar coordinates of distance 5, angle 45 from previous point) would be lost.
- Being able to enter in relative coordinates easily, like r5,2 (displace by 5 units in x and 2 in y from previous point while drawing a polyline) would be lost.
These are some reasons why the most commonly used high precision drawing app does not have separate fields.
> So my suggestion for Michael would be as I said above to make
> a few adjustments in the ui to allow for direct coord. input
The adjustments that you are talking about would remove functionality, and therefore be a step backwards.
> Otherwise its display useless - what I need mouse coordinates for?
It helps you generally see what area of space you are looking out at, you can glance there if you want to know if for example you are in some view way off in outer space.
> ps we actually can do it now - but this is so awkward!
Not really! Just run the Move command, pick your base point, and type in your target point, and you're done!
It's really pretty simple and quick...
> the implication of this change would also be to make yet
> another input field for commands.. and there's still room
> for command line input on the right..
I wish that were true, but on a 1024x768 screen there is actually very little room available to the right.
Please don't make the mistake of thinking that your particular screen configuration is the one that is the one seen by every single user... Different users may have smaller screens that yours and the changes that you are talking about could easily make things work very poorly on their screens.
2629.11 In reply to 2629.9
I was adjsuting points vertically according to some pattern(rule), and it was mush easier for me to input absolute coordinates than use move tool..
My main point was that coordinates adjastment is a sepatate tool for precise placing objects in space - and move is tool is yet another tool mostly used for placing obj in relation to other objects.. (employing different snaps for that part)
So it happened that access to one tool is through another tool (move) which I personally found not so convinient..
But if most people are happy then there should be something I still dont know))
Anyway thanks for explanations!
EDITED: 12 May 2009 by IGOR
2629.12 In reply to 2629.7
Hi igor,
>> There's no complication, what you describe hit tab,
>> type move, pick point, hit tab, change number, hit enter..
> isn't this just too much for a simple offset? :))
Just a quick note here - Burr likes to use the new type-in method to launch commands, that's why he talks there about hitting tab and typing "move".
Most of the time you would click "Transform/Move" instead of that.
The sequence for an offset is not at all difficult, here are the steps:
- Select object you want to offset.
- Run the Transform/Move command.
- Click a base point in your scene.
- Activate distance constraint by typing in the distance you wish to offset followed by <enter> (no click is necessary before typing, just start typing and your keystrokes automatically go into the input box).
- Click the mouse to define which direction you want to offset in and you're done.
These steps are not at all difficult, so I'm not sure why it is such an issue?
There are also other benefits - you don't have to think in advance about which coordinate you have to manipulate, you just type in a distance and get to specify which direction the offset will take place by using your mouse.
That also means you are not limited to only offset only in a major axis direction, you can define the direction between any 2 points that you can snap on to. This can be very important when you are working on a complex model and you want something to have a relationship to a particular existing piece of the model rather than only aligned to x, y, or z axes.
> just a refinement which all other apps already have..
Actually, they seem to be missing the functionality that I mentioned above. For example in your other apps how do you move this square by 5 units along the diagonal direction of the larger rectangle:
In MoI you do it by just following the same steps that I wrote above, just pick the base point on the corner, and the target point for the direction in the opposite corner.
That's the kind of precision control that is good to have - if your other apps can't do that, then how would you possibly categorize them as a "precision" drawing app?
Here is another simple example - move this circle by 5 units along the curve's perpendicular:
Again, easily done in MoI by following the exact same steps above, pick the base point at the circle's origin, and then type 5<enter> to activate distance constraint, then pick the direction with straight snap to follow the perpendicular along the curve.
These are some examples that I hope will show you why the more general purpose offset method that MoI is able to do can be helpful.
The methods that you keep referring to would remove functionality and make it impossible to get these results.
EDITED: 12 May 2009 by MICHAEL GIBSON
2629.13 In reply to 2629.11
Hi Igor,
I don't think I saw your example... If you can post it that would probably help to illustrate it better than just a text description.
But the Move tool in MoI is pretty versatile, you can use it for placing a point at an absolute x,y,z location (just type in the x,y,z value for the target point), as well as for doing offsets.
For doing an offset you just activate the "distance constraint" by typing in a single number (other than 0, that is a shortcut for 0,0,0) rather than a coordinate value.
Similarly there is also "angle constraint" which helps you lock your target point to a specific angle value from the base point.
Both distance and angle constraint work in a similar way through a variety of commands - for example when drawing a line they are also available in the same way as they are in the Move command, to make it possible to draw a line of a specific length or angle, etc...
Probably as you use MoI for doing some more complex models, more of these things will start to make better sense to you - there is a lot of precision control that is gained by the way that MoI is structured to draw things.
2629.14 In reply to 2629.8
Hi Michael....
Yes, it work also in 3D View, nice.... !
Then how to check the location of an object ?
2629.15 In reply to 2629.14
Hi Anis,
Just run any drawing command - draw line, curve, circle, etc... it doesn't matter which one.
Then for the first point, move your mouse to that location so the point that is being picked snaps on to that spot and it will be displayed in that xyz control.
Probably at some point in the future there will be a special "analyze point" command when I get a chance to do a batch of analysis/metric type tools.
A "point object" like you are showing there is just not that frequently used, so it would not really do much good to only display coordinates when one of those special objects are selected.
When you created that point object, that would have actually been a good time to look at the xyz control to see what numeric location it was being positioned at.
2629.16 In reply to 2629.15
Hi Michael....
2629.17 In reply to 2629.16
Any of the tools that draw-move-scale that produce the "snap points" will populate the coords field with the value you want.
2629.18 In reply to 2629.16
Hi Anis,
re: Also I need to know the location of a "vertex".
Just use the exact same technique that I mentioned in the previous message (here)
Again - that is to just run any command that picks points within it, for example the line command.
Move your mouse to that vertex of the box, and then the active point will snap on to it - if it doesn't then it means that you have turned "Object Snap" off - turn it on again in that case by clicking on it in the bottom toolbar so that it is highlighted in orange.
When the point currently being drawn is snapped on to that vertex (it will display as "end" since it is at the end of an edge), then the xyz control will hold the value that you want.
2629.19 In reply to 2629.18
Hi Burr & Michael...
Thanks for the tips.
Yes, it work !
2629.20 In reply to 2629.1
Ehm, you can grab the object (e.g. a corner of rectangle or point), hold mouse down and and start typing coordinates via keyboard, then <Enter> :)
You can use absolute or relative coordinate - e.g. 3,3 or r1,1
Except the relative doesn't work in V2. Why?
Petr
2629.21 In reply to 2629.20
Hi Petr,
It's a bug that was introduced back with CPlane support in v2. The bug happened to be masked if a there were previous point picks before the relative coordinate entry within the same command (such as with drawing a line, etc..).
I've got it fixed up for the next beta, thanks for reporting it!
Show messages:  1-7  8-21
