Close Surface
All  1-14  15
2623.15 In reply to 2623.13
Hi Anis,
> Sometimes we are forgot about what object that
> should selected under an active command.
Some commands that can take a wide variety of different objects will generally not list every possible thing, that would just make for too long and confusing of a prompt.
When there are a lot of different possibilities, then it will just say "objects" - that is intentional to keep the prompts shorter and easier to read.
For stages of a command where there is more specific input required, then in those situations it would be more likely to have it mentioned - for example with Network the prompt says "Select curves for network".
I'd actually recommend that you pick the objects you want to work on before you even run the command, and that prompt will not show at all in that case. Picking objects before the command generally saves a step since you don't have to hit "Done" (or right-click) to indicate that you are finished picking.
Show messages: All  1-14  15
