UI Error under Windows 7
All  1  2-5
2617.2 In reply to 2617.1
Hi Mat - it looks like you are using an older version of the trial, the 1.0 version.
There is an updated version 1.1 which fixes this problem, if you uninstall your current trial version, and download and install the latest one from here: http://moi3d.com/download.htm then that should get things working for you on Windows 7.
2617.3 In reply to 2617.2
thanks alot michael!
2617.4 In reply to 2617.2
Hey michael,
the updater isnt working, its int he install directory and still says it cant find the path.
Im running 64bit Win7, so its installed in the x86 program files directory, could that be
a problem?
2617.5 In reply to 2617.4
Hi Mat - oops, sorry I wasn't clear - you can't use the updater, you must download the full installer.
Here is the direct link:
http://moi3d.com/1.0/trial/moi_v1_trial_setup.exe
That other updater is only for updating the 1.0 full release version to 1.1, not the trial version.
You need to uninstall the old trial version you currently have, then run that new version full installer, and then you should be working under Windows7.
EDITED: 4 May 2009 by MICHAEL GIBSON
Show messages: All  1  2-5
