Browser Selection
All  1-7  8-12
2604.8 In reply to 2604.7
Hi Colin, well currently the sections that you can use are "Styles", "Types", and "Objects".
It sounded like styles made sense to you? Styles are basically for organizing objects into different colored categories, like you were mentioning this is the closest thing to layers that you are used to in Rhino.
The Types section is for doing an action on all objects of a particular type like "hide all curves", or "select all solids". One example of this is after you have built a few surfaces, you may notice that your viewport is pretty cluttered up with a lot of the input curves getting in the way. To hide those, you can go to the Types section, and click the eye icon for "Curves", which will hide all those curves. Or maybe you want to only see curves for some work on them - in that case go to Types and right-click on the eye icon for Curves. That will "isolate" the curves making them the only displayed thing and hiding everything else.
In Rhino there is a set of commands kind of similar to this, such as "SelCrv", "SelSrf", etc... , the Types section in MoI has similar functionality except it provides a few different kinds of actions like Hide/Show/Isolate/Select/Deselect , instead of only being a selection mechanism.
Then "Objects" is a list of all objects that you have assigned a name property to, so that you can refer back to it later on. If you don't care so much about differentiating an object by its color, you can instead just assign a name to it, and then later on hide, show, isolate, select, or deselect that object by using its entry in this section.
Basically though all the sections have a pretty simliar purpose - they are all for doing an action like hiding, showing, selecting, etc... on some defined set of objects.
If you don't have a very complex model, you may not really need to use any of this though, it's basically for when you start to notice that it is taking too much time to click on different pieces of things, or when there is quite a lot of stuff on the screen which is getting in your way and you would like to hide chunks of it with a few clicks, stuff like that.
Hope this helps to explain it a bit!
Also you don't necessarily have to use every section - there are some different sections to try and give you some flexibility and choice in how to organize things. If just one method of organization works fine for you then you can just work with that one section and you don't have to use the others.
2604.9 In reply to 2604.8
Thanks for the explanation & break down of the possible uses.
Just wasn't sure if there was "something more" to all of this than I was presently doing & thinking.
That's partly why I wondered if there might be an "example file" at some point...
...or something similar to your earlier V1 Video Tutorials perhaps?
I guess I'll just wait & see if I'm really going to need anything more than the Styles & Objects.
regards Colin
2604.10 In reply to 2604.9
Hi Colin,
No, probably if you haven't had a feeling like you have been frustrated with trying to keep track of things then many of the things in the browser probably won't really be useful to your situation.
The browser stuff will generally tend to be more useful when you have a pretty complex model made up of a lot of pieces.
If you don't have a whole lot of pieces you may not even need to use anything in the browser at all.
re: Example file or video tutorials... Since it mainly helps out when things get more complex, making a really good example file is also maybe a bit more complex than it normally would be. Similar for a video, I may possibly need to put together a kind of complex project to make that, that would unfortunately take quite a bit of time to do. You'd be amazed how much time it took me just to make those v1 videos that were focused on some more simple projects!
2604.11 In reply to 2604.10
No prob's, Thanks again
regards Colin
2604.12 In reply to 2604.6
I would also like the default action to be that things hidden be left out of current operations until I explicitly unhide them. Could the default action be an option Michael?
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
Show messages: All  1-7  8-12
