Firefox Addon problems on April Beta
2596.1
Just wanted to let you & anyone else know that a recent update by a Firefox Addon has caused some problems with my MoI.
The particular Addon concerned is "DownloadHelper 4.3".
Just wanted to let everyone else know before they started pulling their hair out thinking it's a Bug in MoI when it's clearly not.
In MoI I found that I couldn't Save As, or Export anything...the relevant window would open, but after typing in the name the window would close & nothing happened.
This was also happening in MoI V1 too
I've just solved my problem by disabling the Addon, but you'll need to Restart Firefox.
regards Colin
2596.2 In reply to 2596.1
Hi Colin, thanks for the heads up!
That's certainly unexpected that a Firefox add-on would cause a problem like that...
I guess it must be hooking itself into modifying the file dialog behavior in other applications.
I'm glad you found the thing that was causing it, since it tends to be pretty hard for me to figure out what is going on in situations like that.
2596.3 In reply to 2596.2
Well I found it by pure fluke...I'd just been using MoI to modify a file I was making & went on the net to check a reference image.
As Firefox opened the DownloadHelper came up asking if I wanted to install it's latest update...I clicked OK.
When I'd finished on the net I needed to return to MoI to modify the model...but couldn't Save As?
Tried doing a couple of different things including using MoI V1 to Save & Save As, but to no avail??
That's when it occurred to me the only change in the space of 10mins was the Addon update...a lucky find!!
regards Colin
