Browser Feature Request
All  1-5  6-10
2585.6 In reply to 2585.5
Hi Pilou - undo for assigning styles does not work yet but I plan on fixing that.
Another one ;)
Replace one object A by one object B directly in the prog or by importation ?
2585.8 In reply to 2585.7
Just delete object A and use File/Import or Paste to bring in object B...
Maybe I don't understand what you are referring to specifically though.
Are you maybe thinking of "instances" here where you would replace many copied objects by changing a single source one? That is a different kind of mechanism that I would like to implement in the future, but it will take quite a bit of work separate from the browser to do it though.
2585.9 In reply to 2585.8
Yes something like instance : I have 3 cubes, but for any reasons I want 3 spheres to remplace them :)
2585.10 In reply to 2585.9
Hi Pilou - yes something like "instances" doesn't really have a lot to do with the browser, it will require a lot of work separate from the browser to make something like that work.
Show messages: All  1-5  6-10
