Browser Feature Request
All  1  2-10
2585.2 In reply to 2585.1
Bumping this request back into view. Is it possible to do?
Tony
(aka HamSoles)
2585.3 In reply to 2585.2
Hi Tony sorry I got behind a bit on some replies here.
Yes, I think that having this as per-file data will be feasible. I probably won't attempt it until after finishing up a few other things with the browser first though.
2585.4 In reply to 2585.3
That's okay Michael, you do a great job, so don't worry about it.
Good news, I was hoping this could be in V2.
Cheers.
Tony
(aka HamSoles)
Sorry maybe it's yet asked somewhere
...but there is not CTRL + Z (take back undo(?) ) when you have give a Style to some objects?
2585.6 In reply to 2585.5
Hi Pilou - undo for assigning styles does not work yet but I plan on fixing that.
Another one ;)
Replace one object A by one object B directly in the prog or by importation ?
2585.8 In reply to 2585.7
Just delete object A and use File/Import or Paste to bring in object B...
Maybe I don't understand what you are referring to specifically though.
Are you maybe thinking of "instances" here where you would replace many copied objects by changing a single source one? That is a different kind of mechanism that I would like to implement in the future, but it will take quite a bit of work separate from the browser to do it though.
2585.9 In reply to 2585.8
Yes something like instance : I have 3 cubes, but for any reasons I want 3 spheres to remplace them :)
2585.10 In reply to 2585.9
Hi Pilou - yes something like "instances" doesn't really have a lot to do with the browser, it will require a lot of work separate from the browser to make something like that work.
Show messages: All  1  2-10
