Browser Feature Request
2585.1
You may already have this on your list, but if not, I would like to request that the browser remembers which tabs (and groups when they come along) were open, between sessions.
If I had a choice I would prefer this to be on a per file basis, but if that's not possible then just the state when MoI was closed.
Thanks in advance.
Tony
(aka HamSoles)
2585.2 In reply to 2585.1
Bumping this request back into view. Is it possible to do?
Tony
(aka HamSoles)
2585.3 In reply to 2585.2
Hi Tony sorry I got behind a bit on some replies here.
Yes, I think that having this as per-file data will be feasible. I probably won't attempt it until after finishing up a few other things with the browser first though.
2585.4 In reply to 2585.3
That's okay Michael, you do a great job, so don't worry about it.
Good news, I was hoping this could be in V2.
Cheers.
Tony
(aka HamSoles)
Sorry maybe it's yet asked somewhere
...but there is not CTRL + Z (take back undo(?) ) when you have give a Style to some objects?
2585.6 In reply to 2585.5
Hi Pilou - undo for assigning styles does not work yet but I plan on fixing that.
Another one ;)
Replace one object A by one object B directly in the prog or by importation ?
2585.8 In reply to 2585.7
Just delete object A and use File/Import or Paste to bring in object B...
Maybe I don't understand what you are referring to specifically though.
Are you maybe thinking of "instances" here where you would replace many copied objects by changing a single source one? That is a different kind of mechanism that I would like to implement in the future, but it will take quite a bit of work separate from the browser to do it though.
2585.9 In reply to 2585.8
Yes something like instance : I have 3 cubes, but for any reasons I want 3 spheres to remplace them :)
2585.10 In reply to 2585.9
Hi Pilou - yes something like "instances" doesn't really have a lot to do with the browser, it will require a lot of work separate from the browser to make something like that work.
