Hi Neo, yup that's a UI bug, thanks for reporting it. I have got it fixed up now for the next beta release.
It looks like you have a customized UI there, you can fix up your current version by editing CommandBar.htm - change the <body> tag to be the following:
<body class="CommandBarBody" onload="OnUnitSystemChanged();">
That should tune it up.
The onload="" part is what was missing - without it that coordinate entry table was not getting expanded during initial load to its slightly wider size which is needed to make things fit well when there is a units designator present.
