Hi Igor,
Sorry, I'm not really sure what the difference is - I guess you are showing a screenshot there where they look different in AutoCAD? Unfortunately I can't really debug a screenshot, I need actual model examples that I can examine.
> may be a tweak for spheres can be done in options on export - to
> help them be structured like in Rhino or AutoCad
I need to know exactly what the difference is before I would be able to do that.
> Also there was a bug fixed in Rhino for sat fails (as it happened
> only recently - just making sure MoI doesn't have it as well..)
Have you run into any problem with units with the MoI export? If not then there is no bug there... MoI's code for SAT export is totally different than Rhino's so there isn't too much reason to expect for bug reports in Rhino to be the same in MoI...
