Circumference
All  1-3  4-10
2558.4 In reply to 2558.3
Thanks Michael!
Could I see one short input line for reference?
FYI: It's comming up for me with regard to programming 4th axis CNC work. Some of the lessor packages (under 5K) only do whats called "wrapping" which requires manual unfolding in certain aspects. This will help me alot! As you know, I am new to math so when you explain "radians" I have more homework! (57.2958!)
I'v been looking at Lamina which is cool, but for some other specialized work.
I very much appreciate your time in answering these things for me that really have nothing to do with the development of MoI. I'll always try to give back somehow.
Burr
2558.5 In reply to 2558.4
Hi Burr, no problem!
Did that make sense for how to use that formula inside of MoI?
Just in case here is a step-by-step for how to use it.
Say you want to create an arc of radius 5.5 that has a length of 8.1 units.
To begin with, start the Draw curve / Arc / Center command.
Pick the center point somewhere that you want to place the arc at.
For the start point of the arc, type in 5.5 <enter> to activate distance constraint. That will make the next point you pick be constrained to be 5.5 units away from that center point, that is how you set a specific radius value when drawing an arc with that particular arc tool.
Then click to place that start arc point.
Now the Arc command will be at the prompt that has an Angle: value you can enter.
This is where you enter that forumla - to enter it press the Tab key to put keyboard focus into that Angle box (if you enter numerals your focus will go there automatically but since we are entering an expression that starts with a parenthesis character it won't go there automatically so hit tab to do it).
Then you type in the formula: (8.1 * 180)/(5.5 * PI) <enter>
So note there that I used this formula: (Length * 180) / (Radius * PI) but replaced the Length and Radius with the specific values for length and radius that you want to create for this arc.
So those steps above will make an arc that has a length of 8.1 units.
EDITED: 6 Apr 2009 by MICHAEL GIBSON
2558.6 In reply to 2558.4
Hi Burr,
I think I wrote that last message before seeing this, but that one has step-by-step instructions, let me know if you get stuck on any step and I will show you an illustration for that one.
2558.7 In reply to 2558.6
That was it and it looks like that is exactly what I need to do my "arc by length" thing.
Thanks again.
2558.8 In reply to 2558.6
I dont think the kids are going to understand when I tell them I'm a "wrapper". (dancing around the house)
Thanks again Michael!
I'm now going to go to the other forum and post like I'm some kind of genius or something. But if questioned, I'll have to say I have a "secret friend" that can answer all my questions. :) (and of course, Danny!)
2558.9 In reply to 2558.8
Hi Burr, that's great that will work for you!
That new formula evaluation for v2 came in handy for this one...
2558.10 In reply to 2558.8
Gee thanks Burr, secret friends maybe, as for answering questions, some, not all.
Show messages: All  1-3  4-10
