Icons ?
 1-19  20-39  40-53
2557.40
If you look at SpaceClaim, SolidWorks, Solid Edge, AutoCAD, Inventor etc. look at the technologies they use, there are common components, many use Parasolid, Spatial etc. to provide their features and functions. If UI design is also standardized, where can the vendors find the room for innovation, for differentiation and how can they truly support the 3D-based design workflow? I guess the answer is that the Devil is truly in the details.
MoI's UI is Cool and thanks to Michael is not Ribbon'ed up. Also one of the most impressive UI designs I've seen is the forthcoming Siemens NX 6. de-cluttered and minimized.
EDITED: 9 Apr 2009 by YANNADA
2557.41
HI all how about more color make easy to the brain and the eye flower pot
2557.42 In reply to 2557.41
Maybe not : True Space has these numerous color icons !
Colors disturb regard and don't help many more than a quiet uniform peacefull UI ;)
There is fight between colors and drawing itself of the icon ;)
It's like a patchwork!
Despite of that cool filling colors :)
2557.43 In reply to 2557.38
Hi OSTexo,
> For example, the "Extend" icon in my opinion could use some minor
> action element to indicate the line extension. It's really nitpicking
> since the icon supports the text enough for me to realize the action <...>
Yeah, that's a pretty good example where having both the icon and the text together just helps to smooth things out by quite a bit.
It can often turn out to be difficult (or even practically impossible) to make a perfect representation of a command in an icon, especially when there are things like several stages of actions in the command.
The text labels help to make the UI more "browsable". One thing that I really dislike a lot is when you are confronted only with a big block of cryptic icons and then you have to go and hover your mouse over each one to get a tooltip to see what it does. That behavior of pausing over a bunch of buttons is a big interruption in workflow.
The text labels in MoI's buttons kind of act as an "always on" tooltip that you don't have to pop open with a special action.
I've really tried to avoid tooltips as much as possible, in MoI they are currently only used for things like showing a full long path name when you hover over a truncated file path, not for basic buttons.
2557.44 In reply to 2557.41
HI Iyes....
BTW I like your color icons....
would you like to share it.... :)
Thanks !!!
2557.45 In reply to 2557.44
Hi Anis i haven't done all of them yet only whats visible in the picture
2557.46 In reply to 2557.45
Hi Iyes,
Very nice icons for MoI, hope you can create for all MoI icons.... :)
Why you not create "colors icons" for default MoI ?
I wish you can give us choice to use grey color or full color.
In my opinion, icons with color make user easy to find the correct command.
Also very nice in my eyes... :)
Thanks Iyes... !!!
- anis
2557.47 In reply to 2557.46
Hi Anis,
Well, mostly because it would take extra work but not really give any benefit to the majority of people.
I only have a limited amount of time, so if I spent a lot of time working on several different kinds of icon choices, that would take time away from working on other features.
Would you prefer to have colored icons instead of object organization tools or faster meshing for example?
2557.48 In reply to 2557.47
Hi Michael...
Yes, of course I can understand your concern.
But anyway, Is it difficult to "convert" grey icon to color icon ?
Is there any software that can help us on this ?
Thanks !!!
2557.49 In reply to 2557.48
Hi Anis,
Well, it is not too difficult to do a single one...
But anything that adds more time to the whole process of making new features is kind of bad for me. It's not even necessarily about how long it would take to convert the existing ones - having multiple sets of icons means that I would have some additional process to do in the future as well every time I need to add something to the UI.
So it would need to provide some kind of noticeable benefit to make that worthwhile for me to add to my whole general process.
Photoshop?
2557.50 In reply to 2557.49
Hi Michael...
Which feature I have to use in photoshop that similar to Gimp ?
As replacement I think I can use Gimp.
2557.51 In reply to 2557.50
Hi Anis,
I actually don't use Photoshop myself, so I won't really be the best person to help you - I use Paint Shop Pro for my image handling work.
You could probably find some tutorials searching with Google, trying searching for something like "photoshop colorize", or something similar to that.
2557.52 In reply to 2557.51
Yes, another Paint Shop Pro user! Go Michael...
David
2557.53
I use IconWorkhop for all my icon related chores
http://www.axialis.com/iconworkshop/
Its object oriented approach to icon construction makes it a bit quicker than working from scratch...
-Will
Show messages:  1-19  20-39  40-53
