Installing the 1.1 update to a trial version.
2551.1
Hello
I have a trial version that started having issues when i installed ie8. I've downloaded the v1.1 update, but i get the message "Unable to determine install path". I've tried running the update from C:\program files (x86)\MOI 1.0 trial and from the directory where i downloaded the trial version. In each instance i get the same message.
The machine is running Windows Server 2008 (64) if that makes any difference.
Thanks in advance for your help!
Steve B
2551.2 In reply to 2551.1
Hi Steve, that update patch is only for upgrading a non-trial version 1.0 .
The trial version has been updated too, but you need to download the full installer for it from here: http://moi3d.com/1.0/trial/moi_v1_trial_setup.exe .
If you uninstall the trial currently on your machine, and then download this updated one and install it, then that should resolve your problem. Please let me know if it doesn't.
2551.3 In reply to 2551.2
Thanks!
That solved the problem
