Suggestions for sweep and loft operations -
All  1  2-5
255.2 In reply to 255.1
> I would prefer lofting to be a series of closed curves and a path curve
In MoI, the sweep tool gives you the ability to have multiple profiles along a path.
Maybe you could show an example of the loft in MAX so I could understand you better?
Did you see my other post about the auto-placement mode? This allows for putting the profiles down flat, where they are easier to edit for history updates - you should be able to see the changes in real time as you edit the profiles.
255.3 In reply to 255.2
Haven't tried that, I'll make a test, not sure how I can do this.
As for the MAX example, it's like this... Use a curve as a path, draw anywhere the profiles as you want, and then with a slider you can adjust the % or length of the path where each profile is used. For example at 0% use profile1, at 15% profle2, at 32% again profile1, at 85% profile3, and end with profile 2 at 100%.
Check the attachment, hope it's clear. I think it is not difficult for MOI to achieve this (if of course you agree it's better).
I guess this can be done with MOI too, but what I like is that it's only one command. And, due to history update in MAX, you can change the shape and the loft will be changed automatically.
EDITED: 27 Dec 2006 by JTB
255.4 In reply to 255.3
Here are the steps - draw your path curve, then draw your profiles below it in a left-to-right order:
Select the profiles, run Construct/Sweep, then select the path curve. This will generate this result:
History is active on this sweep at this point, so you can edit either the path or any of the profiles and the sweep will update. Once you have finished editing it to the desired shape, select it and do Construct/Planar to cap off the ends and turn it into a solid.
I do plan on having something along these lines in a future version - for V1 I won't have this ready yet, the profiles will be evenly spaced when you use the "auto-placement" mode like this.
You can still control the spacing manually though - if you place the profiles so that they are actually on the path curve, then MoI will use them in that spot - so if you want to have profile2 at 15% of the way, you can move it there and rotate it perpendicular to the curve, and it will be used at that location.
255.5 In reply to 255.4
< you can move it there and rotate it perpendicular to the curve
Yes that works but no very confortable :)
Show messages: All  1  2-5
