MoI and Acrobat
 1-5  6-25  26-29
2524.6 In reply to 2524.5
That is very cool. Do they make a 3D viewer that works in a browser? Would be nice to have that on a web site.
Ed
Update - I should have searched before asking. There is a browser plug-in. I found a site using it (Hit Play all steps):
http://www.xsive.co.nz/msn/Piston_Rod_Assembly.pdf
EDITED: 27 Mar 2009 by EDDYF
2524.7 In reply to 2524.6
Nice find ed.
For communicating in 3d this is fantastic. Who needs a 2d assembly drawing anymore ?
Seems you can make that with the free Google Sketchup ;)
And it's not only a viewer ;)
http://sketchup.google.com/intl/en/download/gsu.html
If you don't want load the all prog, you can load only the Google Sketchup viewer ;)
http://sketchup.google.com/intl/en/download/gsuviewer.html
EDITED: 27 Mar 2009 by PILOU
2524.9 In reply to 2524.8
Hi Pilou, the difference is that a huge number of people already have an Acrobat reader installed.
So for the basic case where you send a PDF file to someone, they don't have to install any kind of software because they have probably already installed the PDF viewer for reading other kinds of PDFs previously.
That's just easier for the receiving person.
2524.10 In reply to 2524.9
Sure
But it's just 10 second to install the viewer (Size 6 megas)
The defaut with the viewer is it can't read animations made with "external plugins" or with the Dynamic components :(
In this case full prog + plugins are necessary :)
Except that it can read normal animations :)
2524.11 In reply to 2524.10
Pilou a lot of companies that are large enough to have the evil IT department usually do not allow much in the way of downloading viewers, but 99.9% of them have acrobat reader already.
2524.12 In reply to 2524.10
The big advantage with the (free) version of SketchUp is in being able to dimension your MoI object.
Brian
Size: 78.8 KB, Downloaded: 93 times, Dimensions: 1024x640px
2524.13 In reply to 2524.12
That is one giant set of governor flyweights Brian. ;)
< Would be nice to have that on a web site
look at 3Dvia http://www.3dvia.com/users/pilou :)
with a TopMod model here
And My 3D model for the Moi contest :)
http://www.3dvia.com/Pilou/models/3D6C61330517293B
Filament is the French name of the "Helper" by Disney ;)
2524.15 In reply to 2524.14
The main point I was trying to make is the file is saved into Acrobat PDF as a Solid &
file size is very small.
No intention to have a peeing match over who's viewer is better, cheaper or free-er.;)
I use PDF's with my clients and they have no intention/desire to install or learn a 3D program.
I also posted this because I'm finding that the files load into 3D Reviewer the same way
as Acrobat, as separate components (non-grouped faces) and was hoping that MoI ver.2 style
groupings can help to pre-group components for coloring/material before saving/export.
2524.16 In reply to 2524.15
Hi danperk,
Have you tried *.stp export from MoI of an assembly, I think this will read in Acrobat as separate objects instead of surfaces.
2524.17 In reply to 2524.15
Hi danperk, I believe that it is going to work to have styles set in MoI translate out to PDFs.
But it depends on how they did things in that PDF generator.
My current plan is to export styles in MoI as layers in the 3DM file. If they pick up on layers then it should work.
2524.18
Thanks Danny, tried a step file and it worked perfectly! :)
I upgraded from Adobe Acrobat Pro which I purchased from another supplier,
had no problems installing or registering, might want to check them out:
http://store.purplus.net/adacpro9ex.html
That's good news, I haven't had any luck converting 3dm files yet, not in the import list,
but I did find this in the Acrobat directory:
Will have to do more research.
BTW Brian, Reader has the ability to dimension models.
2524.19 In reply to 2524.18
Hi danperk, I thought that Acrobat supported 3DM files directly...
I see now in your original message you mentioned IGES format. There is a concept of a "level" in IGES which is like a layer. I'm not sure yet if the software library that I'm using for IGES is set up to associate a color with a level instead of an object though.
Maybe 3DM is something that you have to enable. If you can enable it that will probably be the way to go.
2524.20 In reply to 2524.18
Thanks for the link danperk, it's the cheapest so far :)
Yes Michael, I know styles will work as layers and I know it will work seamlessly, we're waiting dude............we're waiting.
2524.21 In reply to 2524.20
It'll also cook your breakfast and do your taxes!
Maybe in v30 ... ;)
2524.22 In reply to 2524.20
The attached is to make Grendell (well?) happier!
danpark
That the Acrobat reader can dimension?---I will be busy for a while!
Brian
Size: 68.9 KB, Downloaded: 51 times, Dimensions: 1024x754px
The animation of the different Piston's pieces above are made inside Acrobat or in another prog?
2524.24 In reply to 2524.23
The animation is done within Acrobat, it is a very powerful communication tool, if you search 'Acrobat 3D' on youtube there are a few videos there.
2524.25 In reply to 2524.23
I was just kidding Brian
Pilou - You can make animations in the 3D Toolkit that comes with Acrobat 3D. It uses standard keyframe approach.
Oops, sorry Danny, same post.
Show messages:  1-5  6-25  26-29
