fillet problems
All  1-8  9-11
2510.9 In reply to 2510.6
Hi Armin,
> One more question. In case I run into another split face in
> the future, is there a way to repair that without recreating
> the part?
Often times you can do a bit of localized surgery to the shape rather than full rebuild.
For example, you can select faces, delete them, sweep in a replacement face, trim if necessary to the other existing edges, then use Join to glue it in and make a solid again.
There is a tutorial here: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
which goes into some details on how to do some "low level" surface tweaking type stuff, like in that case it is a boolean that was done in the wrong place, and the tutorial is about how to salvage the shape by repairing localized areas of it.
> I guess I could delete that face and just fill it in with the planar command?
Yeah the things you want to repair are all planar then that is the easiest way.
2510.10 In reply to 2510.9
Hi Michael, thanks again. Didn't know you can box select the way you explained it.
Armin
2510.11 In reply to 2510.10
Hi Armin, no problem!
I think that kind of edge selection is covered in one part of the Pod video tutorial if I remember right. Those videos are available from here: http://moi3d.com/1.0/docs/tutorials.htm
Those are definitely worth watching since they go kind of step-by-step through the whole workflow to build a few things.
Show messages: All  1-8  9-11
