Backgroung image edit
 1-19  20-31
2501.20 In reply to 2501.19
> yes when you draw first that easy but seems
> impossible if image is yet existing ;)
Yeah it won't work to modify the existing image, but it's not impossible to get the final result you want. Just delete the existing one and draw a new one and you will have it...
Does that do the job you want there? If so then I'm not sure if there is really a problem that needs to be solved.
2501.21 In reply to 2501.20
Problem is as you can move and rotate yet in 3D view on the existing plan you want have the other rotation so frustration :)
2501.22 In reply to 2501.20
Frenchy's picture will work as he asked. In the draw box he must choose "With Objects". Then you can grab that image that is flat on the ground and move it up to the top corner of his object (3d view) then use the roatte widget to rotate it down to match the angle.
2501.23 In reply to 2501.21
Solution to frustration: Delete the image and draw a new one flat on the plane. You get the result you want, it only takes a few seconds, so frustration is ended quickly! :)
Why stay frustrated when there is an easy method to get what you need?
2501.24 In reply to 2501.22
@ Burr Seems not ;)
@ Michael
I am agree with you for how obtain the same result ;)
It's just that seems a "natural missing"
EDITED: 21 Mar 2009 by PILOU
2501.25 In reply to 2501.24
It's not really a big problem area to solve, since background images are not really altered in fine degrees like that from their initial placement in their typical usage.
It would be nice to have it in the future, but since there is a very simple existing solution it just isn't a high priority compared to other things...
2501.26 In reply to 2501.25
Of course! :)
2501.27
OK, I get it now ! As I thought, it was just a case of my getting into a mental block. I have a tendency to over engineer things. Simple tricks do not always come to me right away.
Thanks for your time on this. It is much appreciated.
Jean-Paul
2501.28 In reply to 2501.27
No problem Jean-Paul, I'm glad that it makes sense now!
2501.29 In reply to 2501.28
program that is used to create these animations in gif's
2501.30 In reply to 2501.29
Hi thaisregina, I use Camtasia Studio to create those animated GIFs from screen captures: http://www.techsmith.com/camtasia/
2501.31 In reply to 2501.30
Hi
Michael Gibson THANK YOU!
My congratulations and MoI is wonderful
I'm taking the first steps with the tutorials that
found here hope this will be easier to model
Organic modeling and curtains in sketchup
Show messages:  1-19  20-31
