Promising!
All  1-6  7-13
25.7 In reply to 25.6
You can copy and paste any visible lines. Or are you looking for something different?
Trim any volume by a plan and you will have any isocurve :)
25.9 In reply to 25.6
You can extract edge curves right now by selecting the edge curves, then doing a copy/paste. This works for individual surfaces of a solid as well.
You can also select the edges, and then use the new control+drag to drag off a duplicate copy of them.
I think that I'll be able to add an extract isoparm type function later on.
25.10
I have a lot of problem to select what i want (surface, curve...) Everytime i click on one curve, an other one is selected far from the one i want. What's going on?
25.11 In reply to 25.10
Hmmm, I haven't heard of anything like this before...
When you move your mouse over the curves, do the ones near the mouse get the selection preview glow over them? Or do the ones far away from the mouse glow?
Does this happen to you more often on a particular model file? If it does, can you please post the model file so I can take a look at it?
25.12 In reply to 25.11
It's the one far away who glow.
it's happen everytime for anything...simple, i just open Mol and create a line. I want to select it so i move my mouse on it and...nothing happen. I can't select it. The only way i find to select it is to make a left click and draw a big rectangle around it.
EDIT: I tried at home on another computer and there is no problem, so i guess there is something wrong with my computer at work. Tomorow i will reinstalled Moi and see if i still get the same thing.
Hyltom
EDITED: 8 Sep 2006 by HYLTOM
25.13 In reply to 25.12
Hi Hyltom, what video card to you have at work?
The selection mechanism in MoI is dependent on reading some information back from your video card, if the video card is not functioning properly, it could cause strange problems like you describe.
My guess is that somehow the video card is flipping some internal screen information upside down or something.
You may want to see if there are any updated drivers for your video card, it's possible that getting updated drivers could fix this problem.
Show messages: All  1-6  7-13
