Trim by isocurve
All  1-6  7-9
2498.7 In reply to 2498.6
Thanks.....it makes sense, now how do you untrim?
Sorry for the barrage of questions, I'm rather new to MOI and I'm evaluating its workflow for future projects..
So far I think there's a few features that still need to be implemented but its foundation and workflow are very solid and intuitive...much more than Rhino..
2498.8 In reply to 2498.7
Hi niko - to untrim in MoI you need to select all the boundary edges (which must be unattached to other surfaces, use Edit/Separate if necessary to break a surface out from its joined neighbors to be an individual object) and then hit delete.
If you select one edge of a surface, you can also use Ctrl+A to select them all instead of manually picking them.
There's also a tutorial available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
which covers that much more extensively. That's about how to repair a boolean that was done in the wrong place.
I think this was mentioned on the other thread as well, but just to make sure - you can use Copy/Paste to share objects back and forth between MoI and Rhino. So if you need to occasionally use a tool that is only in Rhino and not MoI that can be a pretty effective way to get things done.
2498.9 In reply to 2498.8
Thanks Michael..
I'm aware of the copy and paste but I just wanna see if my entire workflow can be moved to MOI.
Show messages: All  1-6  7-9
