Trim with plane
2481.1
Hello guys.
sorry but I cant resolve this task.
I would like to trim the peak by plane. The Plane is extruded from a line and the peak consist of simple planes (rather triangles).
any idea? :)
2481.2 In reply to 2481.1
Hi andras,
I think there are several issues here, I've untrimmed your surfaces and found there were duplicate surfaces, one on top of each other.
Once deleting them I still had problems trimming, then I found that your model was about 40978 units long and 1862296 units away from the origin which are quite huge numbers, so I believe it would be a fitting tolerance problem where Moi is having a hard time getting the accuracies of 0.001 for such large numbers, Michael explains this in several posts with some guidelines:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2445.35
http://moi3d.com/forum/index.php?webtag=MOI&msg=2418.4
The next step was to scale the model way down to a scale factor of 0.01 and bring the model closer to the origin and this seemed to fix the problem, then I re scaled back to your original size.
I would recommend to finish everything at a smaller scale then final scale to the size you want as the very last operation if you need these dimensions at final output.
2481.3 In reply to 2481.2
I could have swore that was Michael answering!
Scale is out of real measure!
And why are they some lines on a same planar face ?
EDITED: 15 Mar 2009 by PILOU
2481.5 In reply to 2481.2
I set System units to "Miles" and it trimmed as expected.
Will try feet next. (Maybe should also try metrics)
(Which with my settings is the same as scaling it)
EDITED: 15 Mar 2009 by BURRMAN
