CaptureViewToClipboard resolution
All  1-6  7-10
2477.7 In reply to 2477.2
Hi PaQ,
> (Looks like 6000*6000 require 103 Mb, at least that's what psp tell me ... )
Looks like PSP would use 24-bit pixels for that case.
The video card generally uses 32-bit pixels for color, so slightly more than that for just the color but then for a 3D viewport you also need a depth buffer as well, so double that again.
So you're looking at something like 6000*6000*8 bytes = 275MB.
So that target definitely won't fit within a 256MB card, you would need a 512MB card to get to that level.
EDITED: 12 Mar 2009 by MICHAEL GIBSON
2477.8 In reply to 2477.5
Hi Andras,
> I reach 4000x4000 and it semms good for plot.
Great! I think it's probably going to be hard to get much higher on a 256MB card. If you need to go much higher than that you'll probably need a 512MB card to do it.
2477.9 In reply to 2477.6
Hi Micha,
> Maybe Michael could implement something internal so that
> the MOI screens itself need less graphic memory.
Actually, I've already done quite a bit of work on that, which is why MoI works so well on a machine with only 32MB of video memory (see this old thread for when that was improved: http://moi3d.com/forum/index.php?webtag=MOI&msg=322.6)
About the only thing left to do would be to temporarily turn off the display completely...
In general if you want to go really high resolution I would recommend having a video card with a larger amount of video memory on it.
2477.10 In reply to 2477.7
I Didn't think about the z-buffer indeed, thanks for the explanation !
Show messages: All  1-6  7-10
