Hey Mr. Guz,
One thing of input I could give for you is before you start sweeping your curves, look closley to make sure things are aligned well. This type of misalignment can create unexpected results! Great thing about MoI is with object snap on and using construction lines, fixing this is a snap.
Use tthe different "flat" views to look at alignment and such.
Also, small little "Hooks" in the end of your curves, to try and round off the corner, can be bad for surfaces. You may want it to be a more smooth curve at the end and then if you want to shape the end better, fillet or cut it with another curve.
Good luck
