Text Tool and Unicode
All  1-5  6-11
2464.6 In reply to 2464.5
Thanks a lot for looking into it Michael. I wouldn't even have attempted a ticket on this with Vue or most other programs. MoI is just so good it gets held to a higher standard. ;)
I appreciate your taking the time on this. It certainly isn't important enough to take the time for coding a special parser or anything. (The layers and colors crowd would have my scalp :D )
2464.7 In reply to 2464.6
You bet ! :)
eric
You have a very simple thing to make :)
Just type your text with any True Type Police in the Window caracters' table and copy paste Inside Moi Text !!!
so try with the "Analectica" from the site above
That works like a charm :)
Have fun hieroglyphics :D
Edit : Alas seems not work for extra Unicode like U + 2CB7 :(
EDITED: 5 Mar 2009 by PILOU
Ok more subtile !
Type your Unicode at the end of the follow line here 2CB7
http://unicode.org/cldr/utility/character.jsp?a=2CB7
goto the page result copy / past the character inside Moi et voilĂ  :)
for another just modify the end address in your navigator :)
Only default it's letter by letter for extra Unicode! :)
2464.10 In reply to 2464.9
Hi Pilou, that should work fine for all Unicode characters in the range of U+0000 to U+FFFF, which includes characters for all current languages in use around the globe, and also quite a lot of symbols are in there too - this is for the Unicode 1.0 standard.
However, in later versions of the Unicode standard they ran out of space in that range and have produced new characters for some specialized purposes like support for archaic languages, etc...
It is these new characters that will not work, due to a limitation in Windows which I described above. But they tend to be not used very often, since for example people don't write very often in Cuneiform these days...
Windows does support these extended characters in other parts like for drawing the text on the screen with the Windows drawing methods. Unfortunately it does not support it in the particular function that MoI needs to use which involves extracting the bezier path information of the characters.
2464.11 In reply to 2464.10
You right!
We can see the result for the Cuneiform Font Cuneiform Akkadian, Unicode 12219
http://unicode.org/cldr/utility/character.jsp?a=12219
but the copy past don't work! :(
Show messages: All  1-5  6-11
