Fillet direction
 1  2-21  22-39
2457.2 In reply to 2457.1
Hi Burr - this actually doesn't make a variable radius fillet - what you get with fillets on curved things like this is the same fillet radius everywhere, but some of the fillet cross-section arcs are smaller and some are larger, depending on the angle that the 2 surfaces meet at in a particular location.
Here's an illustration - here I have 2 arcs both of which have radius 5, that is they are both portions of a circle that has radius 5. But you can see that even though they have equal radius, they can have different lengths:
That's what is variable in the case you've got here - the length/size of each section (I guess you would say "subtended angle"), not the radius.
I've attached a file burr_fillet_arc.3dm which has several cross-sections of the fillet extracted as individual arc curve objects, this may help you to see more clearly what is happening exactly:
If you pick each of those arcs, you'll be able to see that each of them is of radius .125 .
And if you look from the top you'll also be able to see that they are not necessarily all oriented in a static direction like you may also have been thinking:
Hope that may help to show what is going on!
2457.3 In reply to 2457.2
That clarifies well thank you.
2457.4 In reply to 2457.1
Hi Burr,
>Maybe Danny could jump in here and give me a small lesson. I would mucho appreciate it.
Yeah! what Michael said ;)
I know what you mean there, I've had this situation before and I think there are a few discussions on the forum about this situation.
I've attached a work around which gives you more like the picture attached, if you want that, there are a few more steps involved and
you would need to 3d machine it with a ball nose cutter.
The attached file has the steps involved.
EDITED: 26 Jan 2010 by DANTAS
2457.5 In reply to 2457.4
Hi Danny, Thanks for the time there.
I'm not the best communicator.
I have a model with that original fillet on it (The cad/cam package fillets it that way also) and I was trying to understand How it came about that way (From Michael) and looking at how to cut it (You).
I think I solved it but wont know for a bit as our machine is tied up doing some jobs at the moment.
The issue is the original .125 circle used to cut out the hole gets stretched due to the "projection" of the curve on the surface of the cylinder. Most have already suggested using a 3d toolpath to cut it and that works well and is a done deal, though me, being the nut that I am, am trying to figure out how to do it with a profile job (Much faster than a 3d toolpath).
My solution is to take the original 1.25 circle and convert it with "axis-dim*(360/(Pi*2))/radius", which is essentially doing the wrap, then I can run a profile operation on it with a 4th axis rotation. I think this will produce the "Subtended Angle" that we want but I cant proceed until I can run some toolpath and see if the theory jives up.
Thanks again,
Burr
EDITED: 2 Mar 2009 by BURRMAN
2457.6 In reply to 2457.5
Hi Burr,
>I am trying to figure out how to do it with a profile job (Much faster than a 3d toolpath).
I see now.
Yes, I would of called you a nut also in the past until I joined my current company.
We do multi cavitation injection moulds and we use form cutters where ever possible, like you said, it cuts machining time enormously.
It does help when you have your own tooling department with cnc tool & cutter grinders.
Anyhow, good luck!
2457.7 In reply to 2457.6
Thanks Danny,
Thats what my brother said was we would have to cut our own tool for this! But one small operation for a larger gain.
I'll let you know.
2457.8 In reply to 2457.6
Hi Danny, is this the one where you want to get a "constant distance" style fillet rather than the rolling ball type with constant radius?
2457.9 In reply to 2457.8
Michael,
My original question was more for my "how to machine it" understanding and not that "how it should be filleted" should be different.
With that constant fillet, being the fillet that is desired, I have 2 options. I could do it with a 3d toolpath from a 3d model that has the fillet that looks like this:
Or I can cut the curve itself from the cutout:
This is esentially the 1.25 inch circle "surface projected" onto that sphere. We could get the 2d shape of that by wrapping the 2d sphere to the cylinder with a math function of:
wrap dimension*(360/(Pi*2))/radius
Then we could run a 2d toolpath that looks like this: (the light blue represents the cylinder unwrapped)
While turning round stock around its axis. Then a 1/8 inch fillet tool could just make 1 sweep around the edge and be done.
Would it be possible to get both types of fillet for the same situation though?
Burr
2457.10 In reply to 2457.9
Hi Burr, I can't really help you myself with the "how to machine it" part. But when you were asking about which part was variable since when you viewed it from the top it had some skinnier and wider areas to the fillet, that made me think a bit about this alternate way to do fillets.
I'll attach a model here that has this alternate way of doing the fillet, if you want to check it out.
This method of creating the fillet uses a different measurement to control the fillet.
Imagine that this is a cross-section of the fillet piece between 2 surfaces:
With constant distance, instead of controlling the fillet radius you instead control this distance value for the distance between the rails:
However, this does mean that the radius is variable and is constantly changing, the radius grows or shrinks as needed to maintain that distance. So I don't know if it will help out in this particular case or not, maybe not I suppose. But if would, I'd be interested to know!
The geometry library that I'm using has an option for doing constant distance filleting but it seems to be somewhat less reliable than the regular fillet mechanism though.
2457.11 In reply to 2457.10
Thanks for this additional file.
With the original file you posted showing me the actual radius value of the fillet I was looking at was 1/8 inch, just along a longer arc, this made sense from a machining standpoint and I followed a path to figure out how to do it from this type of fillet. A tool couldnt change radius during its path.
However, I like the looks of this last model from an aesthetic point, though a cad program would not want this. It mentally looks right.
I, being the nut that I am, would ask if I could have an option to do "Both!"
I could see cad guy's needing the real world path but in some circumstances this last one "looks" nice.
Can we have both?
Sorry,
Burr
2457.12 In reply to 2457.11
Hi Burr, there isn't any way to have both of these all at the same time since holding one of these things constant makes the other part to be variable.
But do you mean an option so you could switch back and forth between different methods?
A couple of problems with that are first I generally hate adding in extra UI... but maybe that will not be so bad if I put it as another thing in the Shape: dropdown list like this:
Or does that seem weird to have it put inside there?
Then the other problem is that it just does not appear to work quite as well as the standard filleter, but maybe it is not too bad.
2457.13 In reply to 2457.12
I personally like the option in the dropdown, But I'm not the visionary! Ha. It is a variation.
Sleep on it and if you add it, I will like it.
thanks for the time.
2457.14 In reply to 2457.13
Just a note. In our cad/cam package, the current result produced by MoI is equal to the one in our package called "Constant Fillet".
Thought you may want to know this.
2457.15 In reply to 2457.8
Yeah, that's right, as Burr mentioned, for aesthetic reasons, in design it would be nice to have as many fillet options as possible, including variable fillets one day :)
> ... but maybe that will not be so bad if I put it as another thing in the Shape: dropdown list.
That for me seems the more appropriate spot as it does relate to Shape, but I don't know why I feel that Const Dist should come after Circular then the three G's.
2457.16 In reply to 2457.15
Hi Danny,
Yup, but I'm not sure yet if that will be able to get integrated directly into the existing Fillet command or whether it will need a specialized separate command for it, since it kind of involves picking additional information like points on edges, etc...
Yeah that does seem to make sense to group it with circular since it will also generate circular cross-sections just with a different overall shape for the fillet surface.
The only thing that is bad about putting it in the Shape: dropdown is that then you won't have the possible combination of having "constant distance" style for the rails but then also having blend cross-sections rather than circular cross sections.
It is technically possible to have the "rail generation" and the "cross-section shape" as independent things. But I don't really like the proliferation of UI that would cause, putting it under Shape and just having constant distance be circular only makes for a more tidy UI. Also constant distance with a blend cross-section rather than circular cross-section seems like a kind of unusual combination.
2457.17 In reply to 2457.16
Definitely a separate command, especially if your thinking of extending the history function in V4 where you will have the list of varying radii to edit :)
Maybe something like the sweep options dialogue box ?
2457.18 In reply to 2457.17
Hi Danny,
Well, I'm not that happy with having so many options inside of sweep neither, it's not exactly a model that I want to follow unless it is really necessary.
2457.19 In reply to 2457.18
Oh! Ok, it's the simplest sweep options I've seen.
If you want simpler than that, then you have to design a way to have no UI and we just picture what we want in our minds and MoI will pick up our brainwaves and start modelling.
Could you imagine what would come up on the screen from the minds of most males :)
2457.20 In reply to 2457.16
>>>>The only thing that is bad about putting it in the Shape: dropdown is that then you won't have the possible combination of having "constant distance" style for the rails but then also having blend cross-sections rather than circular cross sections.>>>>
Could be poosible to have a "checked" type dropdown you would find in a Menu option where multiple items could be checked.
2457.21 In reply to 2457.20
Hi Burr,
> be checked.
Might be a possibility for the future... The dropdown that is being used there currently though happens to be a kind that can only contain text though.
I think it sounds like having one more item that did constant distance but with a circular cross-section would be useful though, is that correct?
Show messages:  1  2-21  22-39
