vanishing view
All  1  2-5
2452.2 In reply to 2452.1
Thanks Danny, I can repeat that over here.
It appears to be creating a line that is shooting immensly far off in z, one endpoint appears to be at z =
215339230865702500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
which as you can see is a pretty big number. :)
Then a bounding box that size basically ruins the 3D view projection with an overflow.
I guess the right solution is to actually not generate a result when you move the mouse into the Top view, (same as V1), is that right?
I'll take a look tomorrow at fixing this up, should not be too difficult. Thanks for reporting it and taking the screencap!
2452.3 In reply to 2452.2
Yeah, sounds right. This wasn't the actual model I was working on, I just modelled some primitives to see if the actual model I was working on wasn't causing the problem.
How would you pronounce that number in words, that's crazy :o
2452.4 In reply to 2452.3
< How would you pronounce that number in words, that's crazy :o
A googleplex! http://en.wikipedia.org/wiki/Googolplex :)
2452.5 In reply to 2452.3
Hi Danny, this offset-makes-view-disappear problem is fixed up now for the next v2 beta, thanks for reporting it!
Show messages: All  1  2-5
