please help Where is done button,or right click doesnt working?
2450.1
I am beginner and when I draw a line I cannet not finish it because there is no done button,and when I right click it clears all the curve
2450.2 In reply to 2450.1
What version of IE are you using? There was an issue with the IE8 beta that caused buttons to disappear.
2450.3
the trial version the newest,you are right but can I uninstal İE 8?
2450.4 In reply to 2450.3
Did you try the Enter key ?
2450.5 In reply to 2450.4
yes,but no action,I think it is about sp3
right click clears curve and redo the curve command
2450.6
I found the problem Phil u r wonderful,thanx a lot
2450.7 In reply to 2450.3
Hi vertex13, did you find the way to unintall the IE8 beta? It is under the Add/Remove programs in Control panel, but make sure to look for "Windows Internet Explorer 8 beta", so it is alphabetically listed under W.
The IE8 beta release has a bug in it that prevents MoI from showing the Done and Cancel buttons properly.
This is modified in the v2 betas to avoid this problem but I've been waiting to see if they fix the problem in the full release or not before I modify v1.
2450.8 In reply to 2450.7
Thanx Michael for this really really great program,if you have sp3,you must first uninstall sp3 then ie8 rc1,or rc2,it is really pain to uninstall the ie8,
I wonder to see the moi version 2 beta,I think this prg is a thiny revolution
2450.9 In reply to 2450.8
Hi vertex - yeah I would just not recommend installing beta release operating system components on your main production machine... It is going to tend to make problems - better to wait for the final result for something like that.
I will have a trial version of v2 once it is completed, I'm not quite sure when that will be but not a whole lot longer, maybe something around a couple of months from now.
