system decimal display
 1-15  16-35  36-38
2445.36 In reply to 2445.28
Will the trailing zero's option reflect the options setting or just be hard coded at 4?
2445.37 In reply to 2445.36
Hi Burr, it works in combination with the number of decimal places setting.
So for instance if you have Options / General / Decimal display: set to show 2 decimal places, if you enable "Show trailing zeros", you will get numbers displayed like 3.00 , 2.30 , etc..
If you are set up to show 4 decimal places and you enable "Show trailing zeros", you will get numbers displayed like 3.0000 , 2.3000 , etc...
This is all set up now for the next v2 beta.
When "Show trailing zeros" is un-checked (which will be the default initially) you will get numbers like: 3 2.3 , where any zeros to the right of the decimal point are removed (and the decimal point itself removed if it was going to be all zeros to the right) - this is the same as in previous versions.
Thx for the very clear explanations as usual! :)
Show messages:  1-15  16-35  36-38
