Line creation
All  1-10  11-13
2413.11 In reply to 2413.10
Hi Rob,
> Or setting one of the buttons on the navigator as the mode
> switcher which would be sweet so you could control all your
> camera moves with your spare hand without needing to take it off!
Yup, that will work too. The way you set that up is to make a keyboard shortcut to do the action you need, and then in the Space Navigator driver you can tell it to send a keyboard combination to MoI when you hit a particular button on the controller.
The Space Navigator has 2 buttons (one on either side of the device) which can be assigned in this way.
2413.12 In reply to 2413.11
Great - so next question is how do i work out the code for the shortcut or is that something that you have to write?
2413.13 In reply to 2413.12
Hi Rob, usually it is easiest for me to write those, I just didn't mention it yet since the shortcut will not work until the next beta is out.
But here is what you would use when the new beta is out:
script:moi.view.rotationStyle = (moi.view.rotationStyle == 'World' ? 'FirstPerson' : 'World');
That will do a toggle switch between the regular or first person view rotation modes every time you hit that key.
Show messages: All  1-10  11-13
